Our company is now testing the Geomagic for Solidworks and question is that how can I bring point clouds from Scene to Geomagic for solidworks? Main problem is that Scene's export file formats are totally different from what Geomagic for solidworks can open, or am I missing something?
Meshes I can bring to GfS without problem ,but how about the point clouds? Because we are using Scene to make separate point clouds to one.
Thx for your help for advance.
Br,
Veli
Point cloud from SCENE to Geomagic for solidworks
- Full Name: Veli-Niilo Pulkkinen
- Company Details: Simetek Works Oy
- Company Position Title: Design Engineer
- Country: Finland
- Full Name: Miquel Estupinya Gaudioso
- Company Details: CAPTAE DIGITALIZADO 3D
- Company Position Title: DIRECTOR TECNICO
- Country: SPAIN
Re: Point cloud from SCENE to Geomagic for solidworks
Has you tested to import a XYZ (ASCII) format?
Do it first with a little file from Scene. Geomagic don't accept big point clouds.
- 15
- Full Name: SAttaya
- Company Details: Sev1Tech
- Company Position Title: Sr Software Analyst-RemoteSensingEngr
- Has thanked: 127 times
- Been thanked: 17 times
Geomagic's DesignX will take in .fls natively.
You probably will want to install the latest SDK from FARO before you import them.
Register them in SCENE and export to .fls.
Know to work with one of the 5.5 versions
and with the current 6.2.3.9 version of SCENE.
(Don't know about any other GeoMagic products.)
Do know that DesignX has two PT? formats, "?" being either S or X.
- Country: Finland
Thx for the replies. I have tried to .xyz , but nothing happens.
Please note that I'm talking about Geomagic for Solidworks -add in, not the Design X
GfS is add-in which you can buy to Solidworks cad-program.
GfS can import Point Clouds (.asc , .scn , .vtx) and Gridded points ( .3pi, .ac , .btx , .gpd , .ptx)
Do I have to use some 3rd party program to convert the point cloud or something?
Br,
Veli
Br,
Veli
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
Scene exports in ptx format, and I venture that if you rename a .xyz in .asc it should work.
- Full Name: Warren Wilford
- Company Details: Berkshire Dimensions
For Geomagic Wrap I export VRML from Scene and it brings the point cloud into Wrap with color. It takes a long while to export from scene.
Warren
Warren
- Full Name: Szymon Bloch
- Company Details: scan 3D
- Company Position Title: CEO
- Country: Poland
- Skype Name: szymon_bloch
we use Geomagig For SolidWorks, but this plugin is dedicated for points cloud in PLY format. This format of point clouds give Optical scanner.
- Country: Italy
If you need to convert to ply use Cloudcompare.
Mind ply can be ascii or binary, can have points or meshes and some importers are picky..
By the way if you never used it, you cannot miss Cloudcompare.. it's a must have tool.
