Is there any possibilites to change the backgraond color in Cyclone ?
Instead of black, I would like to change to an other color. Is it possible ?
I did not see the option in the preference.
Background color
- Romuald
- I have made 100> posts
- Full Name: CLAVE
- Company Details: www.urbica.fr
- Company Position Title: Project manager
- Matt Young
- Honorary Member
- Full Name: Matt Young
- Has thanked: 45 times
- Been thanked: 40 times
Re: Background color
This is an easy one to miss as there are quite a lot pf preferences to look through in Cyclone.
I like to add a white background so I can make images that will be printed in AutoCad, very usefull.
- TimBeach
- Full Name: Timothy Beach
- Company Details: Hollis
- Company Position Title: Senior Associate - Measured Surveys
- Has thanked: 4 times
- Been thanked: 4 times
Is there any reason why I cant do this when only running Scan/Register and Cloudworx Licences?
I only get the following Options
Although presumeably if i log into our server and the MODEL licence, make changes and set it to a default, it should stay that way regardless of which licence it is running after that?
Ive been wondering about how to do that for a while, mostly for Image Printing...
Thanks for that Tip Matt
Tim
Tim
- Matt Young
- Honorary Member
I think that the option is limited to 'Model' Because of the visual aspect when viewing models, but I agree that it should be available in the even the viewer version, as well as things like limit box's etc.
- Romuald
- Full Name: CLAVE
Yeah, that's it !Matt Young wrote:This is an easy one to miss as there are quite a lot pf preferences to look through in Cyclone.
This preference is also usefull to generate Trueview with White background (or other to adapt to the graphic chart of the customer).
Romuald
- TimBeach
A follow up Q.
Is it then possible to change the colour of the Fence?
As white on White becomes a challenge to know what you are fencing!!
Tim
Tim
- Romuald
- Full Name: CLAVE
It is true, the background white is more for copy screen or generation of the TrueView index page. It is not possible to work with the fencing white.
- [email protected]
- 3
- Full Name: Dany Lachance
- Company Details: distributor and technical support
- Company Position Title: Tech Support
Could it be possible to change the interface color, to be like darker juste like register 360?
