Oil Tank Strapping Software
Discuss all Oil & Gas Industry related issues here.
gsmith
Full Name: Greg Smith
Company Details: Civil Engineer
Country: US
Post by gsmith » Thu Sep 22, 2011 2:26 am
I've scanned a 90,000 Bbl tank to prepare a Gauge Report. I'm wondering if there is any software available to aid in the creation of the Gauge Table. I need to factor internal deadwood, floating roof displacement, etc...
I'm currently extracting the necessary information and creating a spreadsheet to calculate a Capacity Table. It seems there would be software available to expedite and simplify this process.
Matt Young
Full Name: Matt Young
Company Details: Baker Hicks
Re: Oil Tank Strapping Software
Post by Matt Young » Thu Sep 22, 2011 11:06 am
You could try using 3D Reshaper. It will allow you to make a 3D mesh of the tank, which you can use to produce planar sections. The planar sections can then be used to work out an area at each level taken, including deadwood.
Oliver Buerkler
Full Name: Oliver Buerkler
Company Details: FARO Europe GmbH + Co. KG
Company Position Title: Senior Product Manager
Skype Name: oliver_buerkler
Post by Oliver Buerkler » Thu Sep 22, 2011 12:59 pm
I think also all the other established point cloud meshing / re-engineering tools should work. Geomagic, Rapidform and Polyworks for example.
Best regards,
Oliver Bürkler
Oliver Bürkler
FARO Europe GmbH & Co. KG
oliver.buerkler@faro.com
oliver.buerkler@laserscanningforum.com
Blog: http://oliverbuerkler.wordpress.com
Twitter: FARO_LS_PM
Matt Young
Post by Matt Young » Fri Sep 23, 2011 10:58 am
Of course, there are several meshing packages out there but I only have experience with ReShaper.
Phill
Full Name: Phillip Nixon
Company Details: SKM
Post by Phill » Mon Sep 26, 2011 8:16 am
Greg
I remember hearing about these reports at the 2008 Leica HDS conference, but have not done much research into what is required. Could you expand a little on each of the componenet you require, i.e. what is deadwood, floating roof displacment etc. I may be able to assist with some simple programs with a little modification of the unfurl program.
Phill
Nasir
Full Name: Nasir Siddique
Company Details: Petrosult and Unimart
Company Position Title: Petrosult and Unimart
Country: Pakistan
Skype Name: mnasirsiddiq
Post by Nasir » Fri May 11, 2018 10:06 am
Hi, I hape you have developed sometiong. can you share with me on mnasirsiddiq@hotmail.com
Jamesrye
Full Name: James Rye
Post by Jamesrye » Sat May 12, 2018 9:08 am
We have developed our own software and bespoke solution to this issue. We have received laser scan data from clients in Nigeria, India and even some other posters on this forum. Our strapping tables take into account internal "deadwood" etc...
You can see other services that we offer using the link below, please feel free to send me a PM if you would like a quote.
http://storagetanksurveys.com/
pbashiri
Full Name: Peyman Bashiri
Skype Name: pbashiri2003
Post by pbashiri » Sat May 12, 2018 6:40 pm
I am involved in a similar project now. Since the ships geometry changed along all 3 axis, the best approach to understand the shape of the boat`s internal spaces in humble opinion would be to have sections along all 3 axis then have it exported to Rhino or Reshaper to generate the accurate 3D model.
Return to “Oil & Gas Industry”
