BLK360 G2 feature request - Double scan to fill in hole
Martin_au
14
Full Name: Martin Ankor
Company Details: Anon
Has thanked: 6 times
Been thanked: 26 times
Post by Martin_au »
The BLK360 G2 leaves a semicircular hole in the top of its point cloud. When operating outside, or even most of the time indoors, this isn't a problem.
However, when using it inverted to scan pits, wet well and similar it's a big problem, requiring multiple scans to make sure you've got the details, which then makes TruView navigation difficult for users downstream.
A simple solution I'd like to see is to add another scan option which simply continues scanning for a full 360º, filling in the gap. It would obviously take longer, but as it's generally only needed for inverted scans of pits and wells that's not likely to be an issue.
pburrows145
16
Full Name: Paul Burrows
Has thanked: 114 times
Been thanked: 134 times
Re: BLK360 G2 feature request - Double scan to fill in hole
Post by pburrows145 »
Martin_au wrote: Sun Jun 09, 2024 2:49 pm The BLK360 G2 leaves a semicircular hole in the top of its point cloud. When operating outside, or even most of the time indoors, this isn't a problem.
Do you have a contact to share these thoughts with? They wont get far just being posted here... ;)
I shall share the post with the PM team - seems like a good ask, but I am not so sure on the technicalities... :geek:
Martin_au
14
Post by Martin_au »
I do, and will make a request there too.
