I have a mobile laser scanner but this scanner doesn't have RGB camera so just give me none colorized point cloud.
If I use theta Z1 with this MLS, Can I get colorized point cloud like BLK 2 GO?
Can Ricoh theta Z1 colorize point cloud?
- I have made 30-40 posts
- Full Name: juncheol choi
- Company Details: linetek systems
- Company Position Title: Assistant Manager
- Country: south korea
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
Re: Can Ricoh theta Z1 colorize point cloud?
Depends very much on the mobile laser scanner that you are using. It would need to have a mounting point for a camera and the ability to export a trajectory file with position and pose. The colorization software would need this, the camera intrinsic parameters and the offset details from the camera centre to the IMU centre. Good discussion on this here, https://laserscanningforum.com/forum/vi ... p?p=104301 but it relates to static scanning.
I'd recommend talking to your mobile laser scanner manufacturer to see if they can provide this information and take it from there. External camera support is starting to become the norm.
- I have made 50-60 posts
- Full Name: Jakub Kałaska
- Company Details: Geodezja3D
- Country: Poland
- Has thanked: 17 times
- Been thanked: 7 times
I managed to colorize point cloud from FJDynamics S1 slam scanner with ricoh theta sc2 (worse that Z1).
I did this in Agisoft Metashape. Results were quite good.
- smacl
Cool. Was the camera mounted on the SLAM scanner or used with entirely separate static tripod positions? If mounted on the SLAM scanner, we photos taken manually or timed?geodezja3d_pl wrote: ↑Thu May 25, 2023 9:48 am I managed to colorize point cloud from FJDynamics S1 slam scanner with ricoh theta sc2 (worse that Z1).
- Country: Poland
Separate position of photos but I also mounted camera on this scanner but haven't tried it yet. It shoots with 8 sec interval as well so it's possible.
The trick is to mask your hand/body/tripod in Metashape before aligning panos.
Hi geodezja3d_pl,geodezja3d_pl wrote: ↑Thu May 25, 2023 9:48 am I managed to colorize point cloud from FJDynamics S1 slam scanner with ricoh theta sc2 (worse that Z1).
How did you do that?
- Country: Poland
Hi!
Metashape workflow:
- Align panoramas with gcp derived from scans.
- Import point cloud
- Colorize point cloud with panoramas
Metashape workflow:
