After advice on what scanner to purchase....
SGartz
Full Name: Stephen Gartside
Company Details: Cad-Tech Ltd
Company Position Title: Company Director and CAD Monkey
Country: England
Skype Name: STEGartz
Post by SGartz »
I am looking to purchase a laser scanner but I am mindful of the cost so I want to find one to fit my purpose.
I am a draughtsman and carry out many site surveys. I would like a scanner that can capture data in the field, then I can take this home and bring into Navisworks, plant 3D, Inventor etc. and design my pipe run or structures around this. I spend hours measuring up in the field. I saw the BLK360 and thought this might be the ideal tool but I have heard mixed reviews on it's accuracy.
I don't wish to hire one as I need to work with one on a daily basis really. My budget would be around 20k and I would like the scanner to auto register the scans if possible, or use the ball target things like the Faro one I have seen does. Basically, I need something that captures the data in the field which I can use back at my office, the range doesn't have to be too far, maybe up to 20m max I would imagine.
Any advice would be much appreciated. The last time I used a scanner was when Phil Marsh gave me a days training about 7 years ago and i've slept since then! :D
I obviously like the look of the RTC360 but that would be out of my budget.
bdawood
Full Name: Bashar Dawood
Country: Calgary Canada
Has thanked: 5 times
Been thanked: 8 times
Re: After advice on what scanner to purchase....
Post by bdawood »
If you are an Autodesk guy then stick with Faro, M70 or S70, or even try the X series, leica is expensive and you will end up with lots of annual fees supports for items that should be not on its own to start with, in addition to that, the two mules (Autodesk and Hexagon) keeps on kicking each other and you will be in their way so stick with one product line, BTW, I had the feeling that Autodesk will purchase Faro, but this is my opinion.
SGartz
Country: England
Post by SGartz »
I'll look into the M70 or S70, thanks, this is a good start. Regarding software I am a bit of a whizz, I have had a play with cyclone and it seems pretty straight forwards. My main aim would be to model piping routes from point clouds I guess so an extension to Plant 3D might work for me.
bdawood
Post by bdawood »
I have been using scene and it has been good, and if you are to buy Faro then it is better to buy Scene. You hear a lot about Cyclone and Scene being not so great together.
gabrio
Full Name: Gabrio Rossi
Been thanked: 5 times
Post by gabrio »
SGartz wrote:My main aim would be to model piping routes from point clouds
I suggest you Edgewise BIM suite, by Clearedge3D.
and also to consider an handheld scanner like Mantis Vision F6, to use with or instead of a terrestrial laser scanner.
arch. Gabrio Rossi, MRICS
24121 Bergamo - Italy
+39.035.601.1492
danielgadowski
Full Name: Daniel Gadowski
Post by danielgadowski »
I guess some important questions to be asked first.
What accuracy of a data do you need in order to be able to undertake your task?
Have you worked with a point cloud before?
Does your data need to be accurately leveled?
What color/reflectibility are your objects of interest?
Depending on the answers to the questions above it may be that a blk360 will be your solution. It may be that it wont be accurate enough and you would look at Faro. It may be that your data needs to be dead level in which case things will get a bit more complicated.
Also I would be careful if you want to depends on auto registrations 100% of the time.
SCCS RTC
Full Name: Phil Marsh
Skype Name: Phil.H.Marsh
Been thanked: 20 times
Post by SCCS RTC »
SGartz wrote:
Sun Nov 18, 2018 6:05 pm
HaHa, haven't we all.
Give me a call and I'll find you a solution ;)
M: 07540 201383
E: [email protected]
W: www.sccsurvey.co.uk
ErikVanD
Full Name: Erik van Duffelen
Company Details: Initio Earth Sciences
Country: South Africa
Post by ErikVanD »
I have a good second hand Faro S120 available if you are interested?
