Terrestrial photogrammetry (with a pole)
pfidler
Full Name: Paul Fidler
Company Details: GBB UK Limited
Post by pfidler » Fri May 31, 2019 10:00 am
Good morning!
Does anyone use terrestrial photogrammetry in conjunction with laser scanning? I've been trialling using a pole-mounted digital camera with mixed results. The main use is roads and corridor mapping.
I'm currently using a Nikon D3300 with an 18mm lens on a 5 m pole.
Can anyone provide some tips for ground-based photogrammetry? What is the best technique to capture road environments?
3DForensics
Full Name: Eugene Liscio
Skype Name: eliscio
Re: Terrestrial photogrammetry (with a pole)
Post by 3DForensics » Fri May 31, 2019 1:06 pm
I've done roadways using a couple of different methods. One is using video on my camera and I simply walk in overlapping paths down the section of roadway I want to capture. The other is using photographs (also overlapping). I have a remote trigger that I use on top of the pole. I have even had pretty good success using a GoPro.
Cheers!
Eugene
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Post by max72 » Fri May 31, 2019 1:28 pm
It you are allowed, definitely use a drone for this kind of mapping.
I used photogrammetry with a camera on a pole for buildings and facades, but never for roads.
Ioannis
Full Name: Ioannis Papas
Country: EU
Skype Name: -
Post by Ioannis » Fri May 31, 2019 2:30 pm
Also check that company http://www.heliceo.com/en/produits-pour ... grammetry/
A mirorless camera with triger and gps for positioning i think.
pfidler
Post by pfidler » Mon Jun 03, 2019 2:13 pm
Thanks for the reply folks. The heliceo device looks good but I'm limited to what we have regarding kit (at the moment).
Eugene, that survey looks pretty good. Regarding the photograph process, do you aim the camera down, say 45 degrees, and take photographs in both directions along the road? I attempted to take photographs from both footpaths (on a road with road markings) but I can't get consistent results. I've tried Agisoft's Photoscan and RealityCapture and the results are similar.
I've surveyed a couple of vehicles and got excellent results, I just can't seem to replicate the process with roads. Here's a car I surveyed...
https://sketchfab.com/3d-models/4e7dc24 ... bc31d6c3fd
What lens do you use on the camera? I'm wondering whether a wider angle would help
