Faro Scene Meshing Issues - Recap/Memento & Meshlab
Discuss FARO As-Built software here.
Mark Christy
10
Full Name: Mark Christy
Has thanked: 24 times
Been thanked: 45 times
Re: Faro Scene Meshing Issues - Recap/Memento & Meshlab
Post by Mark Christy »
Chaps,
Arena4D Data Studio and our plugin for Rhino handle large coordinate systems no problem at all.
Also if you use the Pointfuse plugin for meshing with our tools you can mesh large coordinates without having to offset to 0,0,0 and back again (caveat, using the FBX model format). Other 3D model formats don't support the large coordinate systems so you have to be careful what you chose as an output format if you are using large values.
Ultimately we have an end to end solution that will allow you to clean up, fix, align, visualise (in VR if necessary!), generate high res photos and videos (even 360 videos with some work) and ultimately mesh your point cloud data in whatever coordinate system you wish to use. No need to convert, do work arounds, etc..
http://www.veesus.com
Many Thanks
Mark
Return to “FARO As-Built”
