Thread for SCENE software additions/enhancements
3DForensics
Full Name: Eugene Liscio
Skype Name: eliscio
Re: Thread for SCENE software additions/enhancements
Post by 3DForensics »
I would like to have a user controlled threshold on which spheres to use. So, I want to tell Scene not to use any spheres that are below 200 points.
Eugene
Oliver Buerkler
Full Name: Oliver Buerkler
Skype Name: oliver_buerkler
Has thanked: 10 times
Post by Oliver Buerkler »
Hi Eugene.
Doesn´t that already work by only having 200mm defined in the "match sphere" settings?
Best regards,
Oliver Bürkler
Oliver Bürkler
FARO Europe GmbH & Co. KG
Twitter: FARO_LS_PM
flohrd
Full Name: Daniel Flohr
Been thanked: 5 times
Post by flohrd »
zoltan wrote:
Oh, I see. You are using the Point Cloud Polygon Selector instead of the Polygon Selector - a confusing discrepancy. I did not know that deleting Point Cloud points were applied back to the scans. Does it work with Project Point Clouds as well as Scan Point Clouds?
Also, as it had been said, deleting the points outside the selection, or inverting the selection would be best for cropping the entire project to the area of scope and ensuring that the stray points are deleted.
It only works for scan point clouds. Project point clouds are filtered and baked together in a way that we cannot apply changes back to the scan data today.
Inverting selections on point clouds will be part of the next feature update :D
eliscio
Post by eliscio »
Oliver Buerkler wrote:Hi Eugene.
Best regards,
Oliver Bürkler
I mean 200 points, not the sphere size. If Scene detects a sphere with less than 80 points, it turns yellow. I would like to be able to specify that Scene not use any spheres that are below 200 points. This way, spheres that are on the edge of detection are not problematic. This is common in target with high tensions. You see the sphere is close in one scan, but farther away in another.
Also, it would be nice to have the number of points detected for checkered targets visible too since sometimes the checkered targets are detected, but the estimated center of the sphere is off.
JMontie
I have made 60-70 posts
Full Name: James Montie
Company Details: ReCon Engineering
Post by JMontie »
Automatic find checkerboards up to a user distance from scanner. Automatic Find Sphere up to a user defined distance from the scanner.
sreed
Full Name: Scott Reed
Skype Name: sabotva
Post by sreed »
:D
Yes!! I don't use auto detection because of too many false positives and yellow spheres.
LPaulCook
Full Name: L Paul Cook
Been thanked: 4 times
Post by LPaulCook »
I would love to see layers based on content that could be turned on or off like mode Cad or photography programs. Layers could be buildings, vegetation, moving objects like cars or people etc. You then would be able to export any one or more layers, find bear earth for DTM creation, contouring etc.
I would like SCENE to be able to find any defined object like street light, power pole, fire hydrant etc. And find and trace power lines and export .dxf files to bring all of the above layers into and CAD program.
SCENE should also be able to mesh better including tunnels. SCENE should also create contours.
SCENE 2GO should allow me to pick lots of points in a spreadsheet format where I could alsi add a descriptor so I could bring that data into a CAD program instead of just one point saved at,a time to the clipboard.
Got other ideas, post them here.
L. Paul Cook, PLS
www.LPC3D.com
Felix_the_Cat
Full Name: Felix
Been thanked: 18 times
Post by Felix_the_Cat »
Import of textured models please
Ability to save a selection and toggle it's visibility please
flohrd
Post by flohrd »
Felix_the_Cat wrote:
Wed May 09, 2018 2:07 am
Would .obj work for you?
There is actually a way of doing this. It was meant to be used in another way but you can create a selection and fit a mean point.
In the model tree there will be a point fit object below the 3d point.
Right click this fit object and click "select" and it will recreate the original selection.
Maybe this helps.
srichardprologue
Full Name: Sebastien Richard
Company Details: Prologue Systems LLC
Company Position Title: Field Operations
Post by srichardprologue »
3DForensics wrote:
Sat Nov 21, 2015 12:16 am
Eugene
+1 to this, customization of the auto-detection feature would be a huge time-saver.
I'd also like to see the implementation of custom hot-keys.
It would be hugely useful and time saving to be able to hit keys to change my pointer's function.
Return to “FARO SCENE”
