Cluster workflow
charlesdab
Full Name: Charles
Company Details: DFC
Cluster workflow
Post by charlesdab »
Hi All! New to scene with a workflow question on registering clusters to eachother.
I'm trying to capture all the building systems above a drop ceiling. In order to accomplish this I've taken a series of scans in a hallway at ground level and the data looks great. I've put them all into one cluster named "Hallway".
Next, at every point I'm scanning in the drop ceiling I put my S70 on a tripod on a scissor lift, took one scan below the ceiling (to link to the ground cluster) one at the ceiling threshold, and one above the ceiling. I was able to link these three aerial scans at each position into a cluster called LiftPositionX.
Now, I need to link all my lift position clusters to my hallway cluster, but I am finding I'm getting some inaccuracy. I think it's because the lift was swaying a little. So what I am thinking is I need to find a way to register each lift cluster to the good Hallway cluster. But when I add them all together it looks like it's averaging the data from each lift cluster at once.
Is there a way to basically just register one cluster with another cluster? Basically I just want to c2c from the Hallway to each LiftCluster.
Any workflow tips are greatly appreciated! Thanks!
Least
Full Name: Patrick
Company Details: 360
Country: uk
Re: Cluster workflow
Post by Least »
Are you locking the clusters before the c2c?
Also, I think, make the hallway cluster the reference cluster.
charlesdab
Full Name: Charles
Thanks, I'm totally knew to this.
1. When you say lock the hallway cluster you mean go to Hallway > Scan Manager and "lock all"? This just prevents these scans from being moved?
2. How do you assign a "reference cluster"?
Least
Full Name: Patrick
Country: uk
Post by Least »
It locks the group of scans within the cluster, so their relationship to each other 'within' the cluster does not change.
Then carry out a c2c on the clusters.
2. How do you assign a "reference cluster"? see pdf link below
https://knowledge.faro.com/Software/FAR ... _SCENE_4-5
https://faro.box.com/shared/static/xewn ... aqqxus.pdf
charlesdab
Full Name: Charles
Thanks for this Least! It confirms that I was trying the right things... However, it's painfully slow. I thought locking these clusters and registering them against the reference cluster would functionally treat each cluster like one scan, so I was expecting registration times similar to N scans. However, the registration time is extremely long... only 7% in the last twelve hours. I feel like there is a missing piece to this puzzle.
Has thanked: 41 times
Been thanked: 107 times
Post by landmeterbeuckx »
charlesdab wrote:
Mon Jun 29, 2020 3:00 pm
Unload all your scans. This may cause this.
Tel : +32477753126
www.lsbbvba.be
Return to “FARO SCENE”
