Merging Different Scene Projects in one Project on their Respective Global Locations
Arvind
Full Name: Arvind Sharma
Company Details: PIS
Company Position Title: Field BIM Engineer
Country: India
Post by Arvind »
Dear All,
I want to merge 24 different scene projects(which is already registered in Global Survey system) in one project. When I importing the projects all are coming at the center of the cluster of the first project.
I don't want to register them all with the cloud to cloud with each other.
Is it possible to just append these projects in their respective locations?
Thanks in advance.
sreed
Full Name: Scott Reed
Skype Name: sabotva
Has thanked: 7 times
Been thanked: 9 times
Re: Merging Different Scene Projects in one Project on their Respective Global Locations
Post by sreed »
Hi #Arvind,
That's a good question! I do this routinely with a fewer number of lsproj and can think of several workarounds, but would love to hear an official answer how this SHOULD be done. My workaround solution would be clunky with 24 separate Scene projects.
One workaround is using control that is generated from TagLabs "Exporter" plugin. Another is ScanTaxi's "Transformation Manager".
I'm hoping some of the Faro folks will weigh in because this is one of those advanced features of Scene that has eluded me.
Thanks for the question,
-S.
Raimund58
I have made 90-100 posts
Full Name: Raimund Klink
Has thanked: 56 times
Post by Raimund58 »
Hi, you need to apply the transformation of the clusters they had before the import.
If you don't care about the clusters you can just import all the .fls files. Stupid but simple^^
sreed
Skype Name: sabotva
Post by sreed »
I'd imagine that #Arvind wants to preserve the cluster org, the scan managers, the planes/points (spheres/CBT are saved with *.fls), and other components of Scene. If i'm wrong, then yes, just import *.fls files exported from 24 individual Scene *.lsproj.
But if he does want to preserve all the features listed above, then what do you mean by restoring the cluster transformation? Manually copying/pasting the values for the 6 degrees of freedom for each top level cluster in the 24 *.lsproj?
Raimund58
Post by Raimund58 »
sreed wrote:
Wed Mar 18, 2020 12:18 pm
Yeah, that's what I meant. But hopefully there are better solutions... : )
pomped
I have made 80-90 posts
Full Name: Daniel Pompe
Company Details: FARO
Been thanked: 4 times
Post by pomped »
Hi Arvind,
some points to consider when importing / merging projects:
  • Ensure that you have the same transformation on the root object of each project (check the properties) to prevent changes of the global coordinates when importing
  • Give different names to the top-level clusters (directly below root) for all projects to get a clear project structure
Daniel
Arvind
Country: India
Post by Arvind »
Thank you So Much, Everyone, The Issue has been resolved by transforming in original coordinates. :)
sreed
Skype Name: sabotva
Post by sreed »
For my own clarification and the benefit of all on the forum can you elaborate on your solution? Exact steps...
landmeterbeuckx
Full Name: Lieven Beuckx
Has thanked: 37 times
Been thanked: 80 times
Post by landmeterbeuckx »
sreed wrote:
Thu Apr 16, 2020 1:35 pm
Often this happens. They search for a solution to a problem. Solved and you never hear from them again. It's always people with nearly no posts.
I tend to not answer to their questions, a bit of collaboration is necessary to keep this rolling.
My 2 cents!
LSBbvba
Tel : +32477753126
www.lsbbvba.be
Return to “FARO SCENE”
