Faro Scene distance filter issue
- I have made 80-90 posts
- Full Name: James Montie
- Company Details: ReCon Engineering
- Company Position Title: Piping Designer
- Been thanked: 4 times
Just wanted to let everybody know about a glitch I found today. We are using ft for units in scene. We have a distance filter set to 150' in settings. In the Scene released in November and Yesterday it processes with a distance filter set to 42.75'. I've verified this problem exist on two of our processing computers and shared this with Faro support.
- Full Name: Jacob Belcher
- Company Details: Design Systems Inc.
- Company Position Title: Project Engineer
Re: Faro Scene distance filter issue
I'm having the same issue on all computers with the latest SCENE version. Any update on this Faro?
Jacob Belcher | Senior Project Engineer, Mechanical Engineering Group
Design Systems, Inc. | 38799 W. 12 Mile Road | Farmington Hills, MI 48331-2903
Phone: 248-489-4300 x 2386 | Mobile: 734-223-0765 | [email protected] | www.DSIDSC.com
- Full Name: Daniel Pompe
- Company Details: FARO
- Company Position Title: Team Lead Software Engineering
- Been thanked: 19 times
sorry to hear that you have problems.
I tried to reproduce the behavior with SCENE 2019.2.0 and 2019.2.1 but it worked as desired.
Could you please share more details?
Which exact SCENE version are you referring to (and in which one did it still work)?
Are you using the filter from the context menu or as part of the processing task?
Daniel
Daniel
Hi Daniel,
I'm using 2019.2.1. In my settings, I set my unit length to feet. Under Processing, I set my distance filter to 200ft.
Then when I try importing new scans and processing using my preset settings, if I look at the distance filter now, it shows 60.96ft. As if it's converting my 200ft to 60.96m then just changing the unit to ft.
If I keep my units in meters then there's no problem. It's just when I set my units to feet and go to process new scans.
Let me know if you need anymore info.
Thanks,
Jacob Belcher
Thanks,
Jacob Belcher
- I have made 60-70 posts
- Full Name: Manuel Caputo
- Company Position Title: Software Developer
- Country: DE
- Has thanked: 6 times
- Been thanked: 12 times
Hi James, Hi Jacob,
thank you for reporting this issue. This was my fault, I broke this when I changed some processing code during the SCENE 2019.2 development. Sorry
With your description I was quickly able to reproduce the problem and fix the issue. The fix will be part of the upcoming SCENE 2019.2.2 patch. We hope that we can release the patch next week.
Manuel
Manuel
Hi all,
2019.2.2 patch with a fix for the described bug is available now for download: https://knowledge.faro.com/Software/FAR ... _for_SCENE
Daniel
Daniel
