Getting from Faro to AutoCAD
CAD_Man_Dan
Full Name: Dan Carter
Company Details: JWG Survey and Engineering
Company Position Title: Survey Manager
Post by CAD_Man_Dan »
Hi All,
I'm pretty new to processing in Scene at the moment. Ive noticed that the file sizes are huge and the export process takes a tremendous amount of time.
My current work flow is; RAW scan import, preprocess, register, export as ptx, import ptx files to ReCap.
I also tried exporting project from scene as rcp format, but when i viewed it in cad all the scans sat directly on top of each other.
Am i missing an obvious trick that reduces file sizes and to cut down on export times?
Many thanks :-)
blomster
Full Name: Benny Blomster
Company Details: Alandia Map
Country: Finland
Re: Getting from Faro to AutoCAD
Post by blomster »
I assume you have registered it correctly in SCENE (that you don´t have the clouds on top of each other already there).
Export as e57 from SCENE
Import the e57 file in ReCap
Export from ReCap in .PCG, .RCS or what your CAD version handle
Insert in AutoCAD
landmeterbeuckx
Full Name: Lieven Beuckx
Has thanked: 37 times
Been thanked: 76 times
Post by landmeterbeuckx »
i export as a new scene project
import fls from this directory into recap. No bubble view with this one
LSBbvba
Tel : +32477753126
www.lsbbvba.be
CAD_Man_Dan
Awesome i'll give both of those a go :-). Thank you both :-)
tengui
Full Name: NEDELEC Tanguy
Company Details: Prigent et Associes
Post by tengui »
With Recap, just import the .lsproj at the root of your fully registered Scene project (I wipe project history before, but this is probably not necessary). Recap will automatically detect the associated FLS files. No need to export anything.
landmeterbeuckx
tengui wrote:
Fri Nov 08, 2019 12:47 pm
that's correct, this also works but i never erase the history. Always want to keep the complete project. You never know...
LSBbvba
Tel : +32477753126
www.lsbbvba.be
Return to “FARO SCENE”
