Registering 2 Separate Projects Together
TByers
Full Name: Tyler D Byers
Company Details: PCL Constructors LTD
Company Position Title: Field Coordinator
Has thanked: 3 times
Post by TByers »
Hi there,
My team and I have broken up a massive work package into areas. 14 of them to be exact. We are registering each area 1 by 1, as individual SCENE files. Is there a way that we can bring one project (Area), into the other and register them together to make one big file?
Thanks in advance
TommyMaddox
Full Name: Tommy R Maddox III
Company Details: ONSITE3D
Has thanked: 15 times
Been thanked: 11 times
Re: Registering 2 Separate Projects Together
Post by TommyMaddox »
You can do this in a few different ways.
1. You can import registered projects into a master project file. This retains the cluster structure.
2. You can export ordered fls scans into a directory, and then import them into a master project file. The scans will come in registered but without a cluster structure. You can also use this technique to batch rename them.
3. I believe there is a third way involving importing workspaces but I've always just used the first two techniques.
TByers
Post by TByers »
TommyMaddox wrote:
Tue Aug 13, 2019 4:28 pm
THANK YOU for the quick response, Tommy. Would you have any tips to execute the first method? Thanks
TommyMaddox
Create a new project, title it appropriately.
Once you have registered each respective area or group, go into the master project, navigate to the import tab and import projects. You're looking to pick the .lsproj file for each respective area/group project.
You can then register them together, treating them like large clusters.
Note that each scan needs to have a unique name or it will not be imported. If you have 14 separate projects where each scan starts with something generic like "FARO_Scan000" you will want to use the second method instead.
TByers
Post by TByers »
TommyMaddox wrote:
Tue Aug 13, 2019 4:39 pm
Thanks so much for your time. Much Appreciated!
Return to “FARO SCENE”
