Is it possible to do a Flatness Test on a wall? How?
CO96Cons
Full Name: Christian Orozco
Company Details: PCL - Construction
Company Position Title: Field Coordinator
Post by CO96Cons » Mon Apr 15, 2019 6:51 pm
Hope everyone is well. I have been doing floor flatness for different projects and have gotten great numbers and results. Is it possible at all to do a similar test but for a wall? So a Flaness test for a wall?
I tried using the Rythm app Inspector, but it only takes whatever the floor is.
Thanks for the help and I look forward to hearing some answers.
maroshana
Full Name: Maros Hana
Company Details: Surveying and Mapping
Company Position Title: Surveying and Mapping
Re: Is it possible to do a Flatness Test on a wall? How?
Post by maroshana » Mon Apr 15, 2019 8:25 pm
Hi
you could try rotating the point cloud by 90 Degrees and treat it as ground and to your analysis on that.
M
Strider3D
Full Name: James Kennelly
Company Details: Zelus USA
Post by Strider3D » Mon Apr 15, 2019 11:28 pm
Try cloud compare (open source).
You can go 2 ways with it.
1. Create a vertical plane in CAD and export dxf to cloud compare. Do a comparison with the point cloud. Mind your units
2. As suggested rotate the cloud by 90 degrees. Create a height map.
Have fun!
riso2k4
Full Name: Jordan Rising
Company Details: Flight Evolved
Company Position Title: Co-Founder - CTO
Post by riso2k4 » Tue Apr 16, 2019 1:46 am
3DReshaper has a "flatness" and "levelness" tool in their survey package.
sreed
Full Name: Scott Reed
Skype Name: sabotva
Post by sreed » Tue Apr 16, 2019 1:52 am
BuildIt for Construction (Faro) makes quick work of this sort of thing. Highly recommend it.
Return to “FARO SCENE”
