FARO announces SCENE 2018 with High Detail Scanning and FARO Laser-HDR
MaZschi
6
Full Name: Marc Zschieschang
Company Details: Private
Company Position Title: Product Manager
Been thanked: 6 times
Post by MaZschi »
Hello communitiy,
I want to inform you about the recent announcement of FARO SCENE 2018. Please read here the press release:
https://faro.gcs-web.com/news-releases/ ... igh-detail
Whats different to the previous Version SCENE 7.1?
- With Firmware 6.3 for the Focus S150 and S350 we integrated the functionality of High Detailed Scan. This allows you to shoot a low resolution scan and rescan areas of interest with a higher resoltuion. This can be used to scan far away targets or objects of interest to gain improved registration accurcy and quality, time savings during the capturing process and lower file size (usually ~ 150MB per Scan). SCENE 2018 supports these detail scans seamlessly and intergates it into the common registration workflows automatically.
- SCENE 2018 introduces a new, FARO uniquie kind of HDR image quality called FARO Laser-HDR™. This function allows you to leverage your intensity values of the scanner to improve the RGB image quality. It works for all FARO laser scanners even if they are not capable of HDR image capturing Like the FARO X series with no HDR. Using FARO Laser-HDR™ you have more details within your images and scan colors especially for very bright and very dark areas, where also usual HDR approaches runs into limits (Combination of HDR scanning and FARO Laser-HDR will result in a never seen image quality!). Here you can find some image samples for the effect of the functionality for FARO X-Series data.
https://faro.box.com/s/lp2v4fqj7lv4v2fpv5coaomr5u1etpk4
- We improved the saving process of SCENE which allows you to reduce time effort for fls scan saving by 50%. Also the quick view is twice as fast now.
- The new SCENE Version allows to export full resolution panoramas independent of your selected scan resolution.
- Some other improvements are integrated for better VR usability and compatbility to latest VR devices, improved error handling procedure, automated scaling of scan manipulators in correspondence view, 75% faster WebShare Cloud and SCENE 2 Go export, improved image compensation for exported images, rendering of textured models in VR and of course it includes smaller Bug fixes
...to me it may looks like the best SCENE Version of the past years ;)
Please share your comments and also feedback to the community how you have leveraged the new SCENE 2018 functions in your daily projects.
Marc Zschieschang
Simon Judd
14
Full Name: simon judd
Company Details: Precision Air Surveys Limited
Re: FARO announces SCENE 2018 with High Detail Scanning and FARO Laser-HDR
Post by Simon Judd »
Marc
Is this available to download yet as no update available in Scene and cannot see it on downloads page.
Simon
MaZschi
6
Post by MaZschi »
Hi Simon,
It will be uploaded and available by today afternoon. I will share an update and route for trial versions.
Marc
Marc Zschieschang
Mortum
5
Full Name: Robin van der Molen
Company Details: ----
Company Position Title: 3D Scanmonkey
Country: Netherlands
Has thanked: 3 times
Post by Mortum »
I still work with the ancient version 4.8 because our IT guy says support for the Photon 120 stops after that version.
Firstly, is that true? if Scene 2018 is able to work with our Faro Photon 120, can we still get te update?
Sincerely, Robin van der Molen
Gear and Software:
Ye olde: Faro Photon 120
Faro Scene: 2023
Geomagic Design X
Autodesk Recap
Oliver Buerkler
15
Full Name: Oliver Buerkler
Company Position Title: Director of Laser Scanning
Skype Name: oliver_buerkler
Has thanked: 38 times
Been thanked: 12 times
Post by Oliver Buerkler »
Hi Robin!
Any SCENE version that is not older than the scanner can read and work with all data of all FARO scanners (and even iQvolution)!
Give it a try - things have changed drastically since those good old times! 8-)
BTW: Great to hear about all those old babies still working - quality and durability does not need to have and exaggerated price! ;)
Best regards,
Oliver Bürkler
Oliver Bürkler
FARO Europe GmbH
Twitter: FARO_LS_PM
Mortum
5
Post by Mortum »
Oliver Buerkler wrote: Tue Aug 28, 2018 11:12 am Hi Robin!
Thats great news, ill inform if i can get the update with our IT guys!
Best regards,
Oliver Bürkler
But i'm getting off topic:
Great new to see all Scene software is backwards compatible! :D
I kinda am getting tired to do all actions manually for every single scan :P and glad to see in newer versions i can process everything in batch :D
Gear and Software:
Faro Scene: 2023
Geomagic Design X
Autodesk Recap
surveypm
I have made 60-70 posts
8
Full Name: Tom Elbich
Company Details: Solid Ventures Inc
Has thanked: 9 times
Been thanked: 5 times
Post by surveypm »
Will the improvements be visible and transfer to the FARO AS-BUILT software platform?
bdawood
7
Full Name: Bashar Dawood
Country: Calgary Canada
Has thanked: 24 times
Been thanked: 15 times
Post by bdawood »
I thought when we purchased our S70, we where told the only difference between it and the S150 and S350 is the range otherwise they all the same, and now we see that they are started to get different, not sure why we invested in this unit if we should have gone with the M70. this is a ripoff too say the least, and with my respect to the car salesmen Faro salesmen are not any better.
sreed
9
Full Name: Scott Reed
Skype Name: sabotva
Has thanked: 16 times
Post by sreed »
FWIW, we were told the same thing when we recently purchased our S70. Was disappointed to learn that some of the firmware enhancements (and now Scene 2018 features) do not apply to the new S70. We were given the impression the only difference was range. Our very capable and helpful vendor has offered to look into the matter on our behalf with Faro corporate.
bdawood
7
Post by bdawood »
I am not sure why they made this difference if they already made it clear by making 2 separate units S70 and M70
Return to “FARO SCENE”
