Importing data captured with Pix4D into FARO Scene
Sjsmith
Full Name: Steve Smith
Company Details: Engineering
Post by Sjsmith » Fri Jun 16, 2017 2:48 pm
I'm new to the group an am sure this topic has been covered. Is there a method to import pix 4D point data into Scene, and align the imported data.
gordonired
I have made 60-70 posts
Full Name: Gordon
Company Details: IRED
Company Position Title: Support Engineer
Re: Importing data captured with Pix4D into FARO Scene
Post by gordonired » Fri Jun 16, 2017 7:48 pm
I have not worked with Pix4D, but if you are trying to import a point cloud, Scene allows the import of .ptx, .pts, .xyz and e57 files. These will import, and you will be able to do registration. I've only used the older version of Scene (5.4), and in this version you need to jump through some hoops before you can register faro scans with external point clouds.
SAttaya
Full Name: Steve Attaya
Company Details: Geocent
Post by SAttaya » Fri Jun 16, 2017 9:29 pm
as of 6.2.4.30, not PTS, maybe you meant PTZ.
gordonired
Full Name: Gordon
Post by gordonired » Fri Jun 16, 2017 10:31 pm
Yes my mistake, it is .ptz
nikitshetti
Full Name: Nikit Shetti
Company Details: Delta V Forensic Engineering
Company Position Title: Senior Forensic Animator
Post by nikitshetti » Mon Jul 09, 2018 9:30 pm
Any luck with aligning pix4d point cloud with scan data in scene ? I was succesfully able to import the pix4d point cloud into Scene but had no luck aligning it with the scan data.
MarkL
Full Name: Mark Lupton
Company Details: Wolverton
Company Position Title: LASER Scanning
Skype Name: markl9999@yahoo.com
Post by MarkL » Tue Jul 10, 2018 12:54 pm
I think you’d be better off picking out some points from the faro scans and applying them as control points in Pix4D. If you then bring the Pix4D las into Scene you could see if c2c tightens it up. I haven’t tried this exactly, but I did compare scan and UAS data in Civil3D by applying faro points to the UAS data in Pix4D.
Thanh cao
Full Name: Cao Phuc Thanh
Company Details: Star Global JSC
Company Position Title: Applications Engineer
Country: Viet Nam
Post by Thanh cao » Mon Sep 10, 2018 4:20 pm
Hi
Here, with point cloud data in Pix4D software you can export to .xyz or .las files. If .xyz files you can import directly into SCENE. If .las you can change to .e57 in Recap. After import point cloud (UAV) data into SCENE, you should processing it. Then using Correspondence View to do registration (PC(uav)vsPC(scanner) and finally you use c2c to algining them.
Best regards
Thanh
Return to “FARO SCENE”
