Applied Control and UCS in Cyclone Register 360
Nicola Frigo
1
Full Name: Nicola Frigo
Company Details: YTD srl
Company Position Title: President of Company
Post by Nicola Frigo »
Good Morning,
1) I am working with cyclone register 360 Plus (BLK edition). I am using "Apply Control" to align my point cloud data with the help of virtual targets. After implementing applied control when I create a new UCS, the "Applied control" does not function anymore. Any idea how can I have both of them function together?
2) After I use apply control, It works completely fine in Cyclone Register 360, however, I opened the project directly in cloudworx and there the project is in its original state, without applied control.
Any leads would be appreciated.
Thanks,
badam
2
Full Name: Adam Berta
Country: Hungary
Has thanked: 45 times
Been thanked: 278 times
Re: Applied Control and UCS in Cyclone Register 360
Post by badam »
In downstream leica apps if you use lgs then there is an ucs selector, applied control will be another ucs defined to the first setup in the bundle, you need to activate that, if you export standardized formats like e57/las you can only activate 1 ucs/export and you must activate it.
