I have registered color E57 files from cyclone REGISTER 360 and pano images JPG (exported separately from register 360). I need to create LFD file in AVEVA POINT CLOUD MANAGER . The converted E57 scans to ZFC and pano images from 360 doesn't overlap well. Does anyone know how to change the orientation of pano images same as ZFC or E57 scans
Register 360 export pano JPG orientation issue
- Full Name: Adam Berta
- Country: Hungary
- Has thanked: 52 times
- Been thanked: 297 times
Re: Register 360 export pano JPG orientation issue
i don't know if aveva supports it but the images are in line without the setup transformations, so you will need to export the transformations (you can export in the newer releases i think in 2022 or later) as well and apply them in aveva, if that is possible.Mirommer wrote: ↑Fri Dec 02, 2022 11:06 pm Hi,
- 1
- Full Name: Ommer mir
- Company Details: NOC
- Country: qatar
In AVEVA it takes minimum three source files (zfc, int and JEPG ) to create the color LFD database, by default if we are using the AVEVA or Z+F product for conversion, registration and generation the start and end of panoramic images are same end and start of scans. But for exported E57 from cyclone 360 and Pano images the start and end are not same.
In 2022 version of cyclone we have the orientation of each pano exported in txt file. But in AVEVA we can't change the orientation of images. Is there any third-party software suggestion for this process ?
- Country: Hungary
this is more likely to be an aveva issue, not a reg360, because if yoiu export the images from the e57 it is perfectly fine, if you apply the translations to the image object.
well, i'm not really sure, but maybe it is possible to create a new cubemap panorama with pyconvert (https://github.com/sunset1995/py360convert) with the e2p function (not sure about the rotations, fov, etc settings) then you could convert that cubemap to a new equirect. But this feels a little bit hacky solution.
- 1
- Country: qatar
Exported images from E57 works perfect but it gives color wherever pointcloud is present rest of the area will appears black, I have facing issue with separate exported pano directly from Cyclone 360
I am working on code in python but it will take time. I was wondering if there is anything already available in market
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
Possibly worth asking this question in the dedicated Aveva forum here, https://laserscanningforum.com/forum/viewforum.php?f=87Mirommer wrote: ↑Fri Dec 02, 2022 11:06 pm Hi,
