Combining laser scan with public lidar data
dsmith5009
2
Full Name: Dennis Smith
Company Details: Forensic Scanning Engineering As Builts
Company Position Title: Manager of Reality Capture
Has thanked: 5 times
Post by dsmith5009 »
Question here - we are attempting to combine a laser scan with publicly available lidar data. We have set local control using an opus solution but when we compare coordinates of features we are off both horizontally and vertically. The coordinates we shot line up on google earth (big whoop). Coordinates from the public lidar coordinate with the map on the NGS Coordinate conversion and transformation tool but not on google earth. Our goal of course is not to line up with google earth... we need our scan to drop in on the public aerial lidar that was shot in 6343 (NAD83 2011 UTM zone 14N). We gathered our data with differential GPS in NAD83 TXSC. Both were vertically shot in NAVD88. Heres the deal, I am not a surveyor and am not pretending to be. This is 100% for our in house purposes as we are investigators. I understand some of you out there will say just stop and hire a surveyor - and most likely we will. Just trying to learn here and would be great if anyone would be so kind to help me understand what we did wrong -- would be very appreciated! Is it a scale factor issue?
badam
1
Full Name: Adam Berta
Country: Hungary
Has thanked: 31 times
Been thanked: 183 times
Re: Combining laser scan with public lidar data
Post by badam »
dsmith5009 wrote: Wed Sep 28, 2022 11:19 pm Question here - we are attempting to combine a laser scan with publicly available lidar data. We have set local control using an opus solution but when we compare coordinates of features we are off both horizontally and vertically. The coordinates we shot line up on google earth (big whoop). Coordinates from the public lidar coordinate with the map on the NGS Coordinate conversion and transformation tool but not on google earth. Our goal of course is not to line up with google earth... we need our scan to drop in on the public aerial lidar that was shot in 6343 (NAD83 2011 UTM zone 14N). We gathered our data with differential GPS in NAD83 TXSC. Both were vertically shot in NAVD88. Heres the deal, I am not a surveyor and am not pretending to be. This is 100% for our in house purposes as we are investigators. I understand some of you out there will say just stop and hire a surveyor - and most likely we will. Just trying to learn here and would be great if anyone would be so kind to help me understand what we did wrong -- would be very appreciated! Is it a scale factor issue?
You should convert your control coordinates to the required datum. there are tools which can do this conversions. here is an example you chose your src and dest coordinate system.
https://epsg.io/transform#s_srs=4326&t_ ... =NaN&y=NaN
and then apply that control to your own dataset.
