Register 360 Render issue
- Full Name: Nathan
- Company Details: Construction
- Company Position Title: Virtual Design
- Has thanked: 6 times
Hello again, I have seem to run into the same issue as I have had before, but this time the cloud preview for individual scans is visible but disappears when I add it to my large bundle. I tried using the zoom command/Z button and it does not fix the
issue this time. Any ideas? See attached image.You do not have the required permissions to view the files attached to this post.
- 1
- Full Name: Adam Berta
- Country: Hungary
- Has thanked: 16 times
- Been thanked: 123 times
Re: Register 360 Render issue
Have you tried to reopen the project?
Change sitemap, or change sitemap to setup cloud back and forth?
If any of these not helps maybe, you deleted the points? (Outside instead of inside)
- Full Name: Nathan
Creating a new site map and moving the bundle over did the trick and the points appeared. But if I move the other scans to the new site map or try to bring the big bundle back to the original site map the points in the bundle disappear again. Doesn't make much sense.
- 1
- Country: Hungary
I haven't seen anything like that in 2020.1, and i don't have much experience with newer builds.
I'd say that you should see the log file for any errors, and send the log file and projectdb/serverdb to leica support they can look at it better. What and how it went wrong. If you send the project db then i can take a lookat it. Maybe i can see anything irregular in it.
- Full Name: Tristan Thibault
- Company Details: BBA
- Company Position Title: Coordonnateur en technologies relevés 3D
the same thing happens to me. Find out that 2 groups were having too many height différence. It solves by itself when I did the registration of the two groups (visual aligment). I zoom out a lot to be able to see the 2 scans.
