Point Cloud Leveling Issue - Register 360 + BLK360
Discuss all Leica Cyclone, Cyclone REGISTER 360 & Cyclone FIELD 360 related issues here.
chris_BLTSMRT
Full Name: Chris Wiesen
Company Details: BLT SMRT LLC
Has thanked: 4 times
Post by chris_BLTSMRT »
Hi All,
I am currently having issues with my scans being registered with the floor having an upward curve on both my longitudinal and transverse axis. I am still new in using the Register 360 software but feel like I have a pretty solid grasp on the workflow having watched many tutorial videos.
Not long ago, an employee had set the scanner up in a doorway and the door pushed the unit over while on a fully extended Leica tripod. :( It left a noticeable dent on the unit but it seemed to be working afterwards. My concern is that we had only done small projects >5,000SF prior to the fall where things registered perfectly and recently been contracted to do >30k+ jobs where I started to notice the issue. Due to not having done a project prior to the fall I cannot use a past project for comparison. I feel like this might be an indication that things are out of calibration since even with targets I am finding it impossible to get the scan to register appropriately.
I have also been trying to use the new "level" tool in Register 360 but am having a hard time understanding whether it should be done for each setup or simply used on an anchor setup to give the optimization tool something to reference. I have tried to google a tutorial on the subject but it seems Leica hasn't had the time to generate a comprehensive manual for this specific feature.
You can see attached the longitudinal section showing the floor curving upwards.
Project Info
Scanner: BLK360 (Mfng:Jan '20)
Last Calibration: 02/21 (Like that matters now)
Software:
Leica Cyclone Field (v3.1.900117) for on-site registration
Leica Cyclone Register 360 (BLK Edition) (v2021.1.2 Build r20092)
Ultimately, I am trying to determine if this is User Error or if this is a symptom of a scanner that needs to be re-calibrated.
Chris Wiesen| President
BLT SMRT, LLC | BIM Software & Solutions
O: 702.744.7848
E: [email protected]
www.bltsmrt.com
badam
Full Name: Adam Berta
Company Details: none
Company Position Title: none
Country: Hungary
Has thanked: 7 times
Been thanked: 24 times
Re: Point Cloud Leveling Issue - Register 360 + BLK360
Post by badam »
Yep that happaned to us, you need to send the device to switzerland and fix/recalibrate it (it'll cost you).
just go into a single scan (setup) and see if you have misalignment in the start/end (where more points should overlap) of the scan, but i'm 99% sure that you have. see below the image
And you have to rescan the whole projects unfortinatelly..
chris_BLTSMRT
Hi Badam,
Yea, that seems to be the case for sure.
I am currently talking with Leica to get an estimate for the repair and a temp unit in the meantime. It's a very frustrating situation.
Thank you for your response.
O: 702.744.7848
www.bltsmrt.com
badam
Country: Hungary
Post by badam »
you could try to use the leveling feature (on every setup) but you will have issues with this dataset. but if the deliverable is a 2d floorplan to demolition or something like that then you may get out some result from this, but send the device to leica asap.
