Cyclone crashes down
Discuss all Cyclone Leica Cyclone, Field 360 & Register 360 related issues here.
Ioannis
Full Name: Ioannis Papas
Country: EU
Skype Name: -
Has thanked: 19 times
Been thanked: 16 times
Post by Ioannis »
Hello to all,
Question 1. I have a small project in cyclone core and I try to do visual registration---> visual alignment after I create a group with 6-7 scan and try to do register the group then cyclone crashes down?
Question 2. I have clean up scans with unnecessary points in control space but in the visual alignment screen, i saw them as in the original scans (before cleaning).
Can anyone help me?
virtuoso
Full Name: Ant
Company Details: Mck
Company Position Title: BIM engineer
Country: Cro
Re: Cyclone crash down
Post by virtuoso »
While you were cleaning points, did you tick Edit Cloud-to Cloud points? When you tick that that means that those deleted points also won't be visible in cloud to cloud alignment.
About crashing... Dunno. Is your PC powerful enough? Mine also tends to crash but when I'm dealing with 500 scans..
Ioannis
Country: EU
Skype Name: -
Post by Ioannis »
Where I can find that option to classic cyclone core?
It's not a computer issue pc is high end.
sim.herrod
Full Name: Simeon Herrod
Has thanked: 17 times
Been thanked: 26 times
Post by sim.herrod »
Ioannis wrote: Wed Oct 28, 2020 1:48 pm It's not a computer issue pc is high end.
Crashes in Cyclone, and for that matter Scene, seem to be an integral part of the joys of working with laser scans...
virtuoso
Full Name: Ant
Country: Cro
Post by virtuoso »
Ioannis wrote: Wed Oct 28, 2020 1:48 pm Where I can find that option to classic cyclone core?
oh sorry I've misread your post. After seeing pictures I automatically assumed you were talking about Register 360. :-o
denbrown2007
Full Name: Denis Morozov
Company Details: Trimetari Consalting
Company Position Title: Engineer Surveyor
Country: Russia
Post by denbrown2007 »
After clearing point clouds in ControlSpace you need to select Tools/Scanner/Set ScanWorld default clouds
Trimetari Consulting LLC
+79062500051
www.trimetari.com
Ioannis
Country: EU
Skype Name: -
Re: Cyclone crashes down
Post by Ioannis »
denbrown2007 Yes i did it but in that case it disables me the button cloud constraint---> auto add cloud constraints.
I used to do the following, after the registration run the '' auto-add cloud constraints '' to be more robust the final product.
But in that case, i can not do this.
Also Cyclone wants some empty space of HDD ? Project is in a separate 2TB M2 disk.
Main disk of system that is 1 TB with 300 gb free space.
Can we set the cyclone to create a folder of .imp (main project file) file to the 2TB m2 disk somehow?
Ioannis
Country: EU
Skype Name: -
Re: Cyclone crashes down (solved)
Post by Ioannis »
Problem solved
Release notes from cyclone!
Support for AMD processor
The AMD Ryzen 9 3900X 12 core processor with 128GB RAM is not a Cyclone supported processor.
Mike Annear
Full Name: Mike Annear
Company Details: Mike Annear
Been thanked: 52 times
Post by Mike Annear »
Hi Ioannis,
Did you get any answer from Leica on this issue ?
I have a similar computer setup to yours, I only rent Cyclone core when I need it.
Mike.
Mike Annear
www.mikeannear.com
QLD, Australia.
Ioannis
Country: EU
Skype Name: -
Post by Ioannis »
Still no answer from Leica!
Return to “Leica Cyclone, Field 360 & Register 360”
