Helllo,
I get an error when optimizing the bundle in REGISTER 360.
"Failed to optimize the given bundle. Encountered numerical issues when attempting to solve".
How can I pass this error or solve it? Where can i see the numerical issues?
Some ideas?
When I try to select two scans from seperate bundles and try to do a visual alignment, I only see one scan in the cyaan-color. The other scan is not viewable. The two scans are in the same area so must certainly be a good overlap.
As you can see in the attachement, the are some scans that are not viewed in the cloud bundle. Maybe this is the reason? How can that happen?
Failed to optimize bundle
- Full Name: Geert
- Company Details: Geert
- Country: Belgium
- Been thanked: 3 times
- Full Name: Amanda Li
- Company Details: CRA Survey
- Company Position Title: Graduate Surveyor
- Has thanked: 5 times
Re: Failed to optimize bundle
last time this happened to us, there's a link shown as "green dash" in the bundle, we removed it and it's fixed.
this is where i got my solution from
- Dang
- Full Name: Dang Duy
- Company Details: GeoInstinct Viet Nam
- Company Position Title: Co-Owner
- Country: VietNam
- Been thanked: 4 times
Ah, I have this happened a lot to me on a particular big project. It usually happens after excessive cleaning or ''removing C2C points" . Restoring some the C2C points from some of the stations should fix this
- gsisman
- Full Name: Steve Long
- Skype Name: gsisman1
- Has thanked: 767 times
- Been thanked: 149 times
This happened early on when we cleaned a lot before fully registering (Adding more redundant crosslinks, etc. The only thing we clean now before registering is remove vegetation and tree crown from C2C part of the DB. Other cleaning do after things are registered.
