RTC360 dat with the wrong position after import
sakul007
Full Name: Luwi
Company Details: own
Company Position Title: geomatik
Country: polska
Post by sakul007 » Wed Aug 14, 2019 6:37 am
Hey guys,
I am struggling with an odd issue. I use RTC360 data with measured position by internal RTC360 GPS (GNSS ?) module. In the Field360 I somehow rotated the whole point cloud which was not corresponding with north direction.
In Register360 in first step IMPORT, I used pre-registered option, place by Geo-coordinates and whole data looked perfect then.
After the importing process whole point cloud gets back to the wrong rotation angle and looked the same as in the Field360 with my rotation error.
IMPORT step in REG360 and correct rotation to the true north:
REVIEW step in REG360 with propagated error from Field360:
An additional question about sphere targets recognition. Why I always get red X for automatically recognized spheres and B/W targets? Even the target was correctly founded I have to do manual targets adding.
regards
Lukas
elsonj
Full Name: James Elson
Company Details: SCCS
Company Position Title: HDS Support
Re: RTC360 dat with the wrong position after import
Post by elsonj » Wed Aug 14, 2019 9:06 am
Hi Lukas ,
In reference to the sphere issue, they will only display a green tick if being used as part of a link.
By using "Match targets" (minimum of 3) and if the targets are located in another setup then they should display a green tick. (See image below)
Regards
James
pburrows145
Full Name: Paul Burrows
Post by pburrows145 » Wed Aug 14, 2019 3:25 pm
Did you try using "Place by geo-coordinates" after the import process?
You are aware this will not export the data as per the GNSS positioning - it's purely a visual "thing" to align the images and the scan data. You still need to apply external control to move it to a grid of your choice.
sakul007
Full Name: Luwi
Country: polska
Post by sakul007 » Thu Aug 15, 2019 9:17 am
Yes, I used "Place by geo-coordinates" after the import process but it doesn't change rotation angle in "Review and Optimize" step. So the GNSS position will not roughly position my point cloud? Then I have to figure out some other way :)
Thank you for the information!
P.S. Do you know the accuracy of the GNSS module in RTC360?
regards
Lukas
Return to “Leica Cyclone”
