Register 360 import
jnicoli
Full Name: Joseph Nicoli
Company Details: Direct Dimensions Inc
Company Position Title: Heritage Scanning Specialist
Register 360 import
Post by jnicoli » Fri Mar 15, 2019 4:24 pm
When I export out scans e57 out of Register360, and then try and import them into an existing project(checked pre-registered), they don't seem to come in the correct position. Is the UCS causing this issue?
Thanks,
Joe
pburrows145
Full Name: Paul Burrows
Re: Register 360 import
Post by pburrows145 » Mon Mar 18, 2019 9:47 am
So, you are trying to bring 2 projects together?
Why not just import the RAW data into the existing project?
GO back to the import stage, add a new site-map and import the data.
Then merge the bundles accordingly.
Also, if you have a CCP (customer care program) on your software (and most people do), then visit https://learning.leica-geosystems.com/login/index.php and do the Cyclone REGISTER 360 training course.
jnicoli
Post by jnicoli » Mon Mar 18, 2019 2:10 pm
I ended up doing that, but at some point, you reach the limit of what's reasonable to do inside of Register 360 (I have a upcoming project slated to contain thousands of scans). I was trying to see if I could register a small number of scans (<200), and then export out a few key "anchor" scans that could then be used to register the next group. But like I said. The scans (e57) seem to drop in a different location on re-import.
I'm also bringing the whole thing into Cyclone Register, as I believe it has a higher scan "limit".
Joe
pburrows145
Post by pburrows145 » Mon Mar 18, 2019 2:49 pm
Just do a REGISTER 360 Project import into Cyclone. No need for E57 in/out then.
You may have to finalize the registration, but everything should be in the right place.
If not, then contact support.
Carbix
Full Name: Daniel Loney
Post by Carbix » Tue Mar 19, 2019 6:12 am
Would he not want to use the multiple site function in Reg360?
Daniel Loney - Owner
Excelsior Measuring inc.
www.ExcelsiorLevel.com
pburrows145
Post by pburrows145 » Tue Mar 19, 2019 1:08 pm
That's been suggested already, see 2nd post
Return to “Leica Cyclone”
