Data cleaning...what is the best method?
James Hall
Full Name: James E Hall
Has thanked: 4 times
Been thanked: 29 times
Re: Data cleaning...what is the best method?
Post by James Hall »
dirtysouthsurveyor wrote:
Thu Oct 04, 2018 7:35 pm
When you say "compact" are you referring to optimizing the database?
I had a 3 mile stretch of an extremely busy roadway that we scanned at night. It was a nightmare cleaning that thing up with region grow because of how quickly it would break the unification. I ended up sectioning off parts of the road with the limit box, flip to ortho profile few then fenced in everything approximately 0.1' above the surface and deleted inside fence.
In retrospect, i wouldn't have brought in every day of data into the same database. Definitely going to keep future projects in separate databases and then clean them as I go. Just not sure of how to register the clean scanworlds together...
A way and not the most elegant, is to select the the cleaned data and export them to an e57 file. Then re-import them (make sure to calculate normals) and registered the cleaned scans. This is also a way to fix a problem scan world.
James,
Origin.KR
Full Name: Kyle Rothwell
Company Details: Origin 4n6
Company Position Title: Tech
Country: usa
Post by Origin.KR »
I have found the Cloth Simulation Fliter used in CloudCompare to be very useful to isolate noise generated from passing traffic.
http://www.cloudcompare.org/doc/wiki/in ... F_(plugin)
Jonny5isAlive
Full Name: Jon Adams
Company Details: Forensic and Architectural Consulting
Company Position Title: Director of 3D Reality Capture
Post by Jonny5isAlive »
Thank you all for your responses!
It sounds like there is still yet room for improvement inside of Cyclone (i.e. keep all the data there, no export/process/reimport) to address the extremely slow process of cleaning scans.
Region grow is nice and does a decent job, but I look forward to a time when selections are made instantly, and deletions as well.
The waiting for these two items is mind-numbingly painful.
I hope something comes soon.
Sent from my SM-N950U using Tapatalk
Yuelin
I have made 80-90 posts
Full Name: Yuelin
Been thanked: 6 times
Post by Yuelin »
Hi Jon,
Regarding to data cleaning, please read my recent posting here: https://laserscanningforum.com/forum/vi ... 984#p73836
Jonny5isAlive
Yuelin wrote:Hi Jon,
Yes, but even with this process, cleaning is a slow affair.
Starts out relatively quick, but the more edits made the slower the process becomes.
Compact/optimize helps some when slow downs occur, but overall selections/deletions are far from instantaneous (which would be ideal).
Has thanked: 45 times
Been thanked: 36 times
Post by Matt Young »
When you are working with very large datasets, instant delete is unlikely to be a thing for a while yet. It's like someone telling you to open a thousand page novel and manually remove every occurrence of a single word. A human could do that but it would take a very long time. Now make the book a point cloud with hundreds of millions of points. The computer has to read all the points, decide which ones are to be hidden (Cyclone does not delete points) and then hide them. When you optimize and compress your database, the points are deleted and the database decreased in size to compensate for the new point count. This is like you re-writing the thousand page book, so that no spaces occur where you removed all the words.
