Modify intensity values in Cyclone
A_Axelsson
Full Name: Anders Axelsson
Company Details: AF Metrology
Country: Sweden
Post by A_Axelsson »
Is it possible to modify intensity values i Cyclone?
I have an older cyclone-database with scans from a C10, where the intensity values ranges from 0 to ~30%.
Is it possible to scale up the intensity values somehow in Cyclone, e.g. by a multiple of 3?
Or do I have to use some other third party software to do that kind of operation?
It would be nice to not have to export/import the whole dataset a couple of times to be able to do this operation..
//Anders
Jamesrye
Full Name: James Rye
Been thanked: 10 times
Re: Modify intensity values in Cyclone
Post by Jamesrye »
Anders,
Yes, it's possible to modify the intensity values. If you open your scan and set the global colour map to on. Then you can edit global colour map and just change the max/min range in there.
James
wishgranter
Full Name: Milos Lukac
Company Details: MHB
Country: Slovakia
Skype Name: fugatron78
Post by wishgranter »
Hi Jamesrye
Its possible to do same on let say FARO scann datas ? As they have "all" in blue color that not represent proper INTENSITY values i need to change it to some more realistic values ( must be not accurate, just to read out properly )
wishgranter
Country: Slovakia
What to change to get more realistic INTENSITY values ?
Tookie
Forum Supporter
Forum Supporter
Full Name: Iain Took
Company Details: WMP
Post by Tookie »
If you change the minimum and maximum numbers you will get more colour range, try adjusting the minimum to 0.2 for example.
