Hi All, I wonder if you can help.
In scanning a site I have full coverage of the area I want, My final scan was the rear side of a wall obscured from other views.
All scans register fine including the last however when I create the modelspace the final scan does not appear to be there.
I thought this was just down to the point visibility/loading capacity but it appears not as when I investigate a slice the data is still missing.
Registration is through targets and cloud comparison and none of the constraints are disabled.
Any thoughts?
Thanks in advance.
Ali
Missing data after registration
- Full Name: Alison Bentley
- Company Details: WSP
- Company Position Title: Land Surveyor
- LeicaUK_RC
- Full Name: Phil Marsh
- Skype Name: Phil.H.Marsh
- Been thanked: 52 times
Re: Missing data after registration
Does the data appear when you view interim results on just 2 scans at the registration stage?
It does appear to be yes.
Just a Glytch? I've recreated the registration a couple of times to the same avail.
Reimport the data?
Reimport the data?
- stevenramsey
- Full Name: Steven Ramsey
- Company Details: 4DMax
- Skype Name: steven.ramsey
- Has thanked: 30 times
- Been thanked: 72 times
a couple of things to try. as it looks like it is not unified.
How many scans?
turn up the point load and display this will effect the slice as well.
In the registered modelspace select all clouds and delete them, from scanworld exploer turn them all back on
How many scans?
Thanks for the reply,
I had 14 scans, the point display and load unfortunately made no difference as I had tried this.
Selecting clouds, deleting and turning back on in scanworld explorer also didn't work.
Bit the bullet and just started again, registered one cloud at a time checking it was still there after each and it appears to have now worked.
Very odd, never had that before!
Thanks for taking the time to reply, much appreciated.
Ali
Ali
