What scanner was used?
Discuss all Cyclone Leica Cyclone, Field 360 & Register 360 related issues here.
hardworking_intern
Full Name: Justin Benjamin Acu Kang
Company Details: ---
Company Position Title: Intern
Country: Singapore
Post by hardworking_intern »
Is there a way to find out what type of scanners were used in a particular project on a Cyclone database?
Context: We are currently cataloging projects that our company did in the past and most of this were done ages ago by people that have either left the company or returned to their respective countries.
Shrinivas
Full Name: G Shrinivas
Company Details: WeWork
Company Position Title: Reality Capture Specialist
Country: Singapore
Skype Name: g_shrinivas
Re: What scanner was used?
Post by Shrinivas »
I think when you import non-native files you lose that info.
Like PTS and similar just has- Total points, X, Y, Z, and RGB info.
G SHRINIVAS
Matt Young
Full Name: Matt Young
Company Details: Baker Hicks
Has thanked: 45 times
Been thanked: 34 times
Post by Matt Young »
I could tell from subtle differences in the model space, but that comes with years of experience. There is no label to tell you though.
rpettener
Full Name: Robert Pettener
Company Details: Survey Operations
Company Position Title: CAD Development Manager
Post by rpettener »
If you expand the scanworld for each scan in the Cyclone Navigator you will see a scans subfolder. Inside that you can check the object info for each of the scans (green icon) and it will show the scanner details under Make, Model. For some strange reason, though, the scans we have carried out using a P30 are listed as P40.
btylutki
Full Name: Bart Tylutki
Company Details: KSE
Company Position Title: HDS Manager
Country: USA NJ
Post by btylutki »
it looks like Leica decided to get rid of rather useful option "Setup info" and cramp it to "Add/Edit Annotations..."
Right click on ScanWorld and Add/Edit Annotations... It shows scanner model, serial number, firmware version, setup time etc.....
steves01x
Full Name: Steve Smith
Company Details: Scanning
Country: Scotland
Has thanked: 16 times
Been thanked: 17 times
Post by steves01x »
Can you not expand the folder each scan is in the right click for properties? Assuming its the scans imported directly from Leica scanner it will give your model/serial number etc.... but its a slow manual task.
hardworking_intern
Country: Singapore
rpettener wrote:
Wed Oct 09, 2019 9:55 am
This is interesting... is it only for the P30? Does it affect any P20 scans?
hardworking_intern
Country: Singapore
btylutki wrote:
Wed Oct 09, 2019 11:16 am
Found this to work perfectly! Thanks for the help
SCCS RTC
Full Name: Phil Marsh
Skype Name: Phil.H.Marsh
Been thanked: 14 times
Post by SCCS RTC »
Click on the point cloud then right click and select object info
M: 07540 201383
E: [email protected]
W: www.sccsurvey.co.uk
MajorDomo
Full Name: Major Domo
Company Details: VeritasVfx
Company Position Title: ceo
Country: Portugal
Has thanked: 7 times
Been thanked: 27 times
Post by MajorDomo »
hardworking_intern wrote:
Thu Oct 10, 2019 7:20 am
If you were pedantic, you'd have to do this for every scanworld, as multiple scanners could've been used on the same project.
Very easy to happen in multi-year projects.
Return to “Leica Cyclone, Field 360 & Register 360”
