LFM to Recap Conversion
Discuss all AVEVA Suite related issues here.
jtayl71
Full Name: John Taylor
Company Details: ISC Engineering
Company Position Title: Civil Engineer
Post by jtayl71 » Wed Jun 06, 2018 5:00 pm
I have recently been given a large dataset from a client that was done using Z+F scanner for the purpose of bringing the data into AutoCAD for design. I am a FARO guy and have never used anything related to Z+F or LFM. I have downloaded the LFM Server free trial to see if I could export to anyway, but no avail. The client has .ZFS files, .ZFC files along with the .LFM/.LFD file formats. Is there a workflow where I can get these somehow into ReCap without having to purchase a software for a one time use? Thanks for the assistance!
pbashiri
Full Name: Peyman Bashiri
Skype Name: pbashiri2003
Re: LFM to Recap Conversion
Post by pbashiri » Wed Jun 06, 2018 6:41 pm
You can call ZF USA support, They are very good. How big is your data set? I have ZF control maybe I could help you too.
Peyman
jtayl71
Post by jtayl71 » Wed Jun 06, 2018 6:58 pm
Peyman,
Thank you for the response, my dataset is quite large, 700+ individual scan setups, over 800 GB. I will see about contacting ZF USA support. I am able to get the pre-registered scans into recap, but I can't seem to get the registered dataset there.
gabrio
Forum Supporter
Forum Supporter
Full Name: Gabrio Rossi
Post by gabrio » Thu Jun 07, 2018 5:56 am
to make a recap project (rcp file) from zfs files you can import direct zfs dataset in a new recap file: import and skip registration.
My2c
arch. Gabrio Rossi, MRICS
g.rossi@intellegere.net
24121 Bergamo - Italy
+39.035.601.1492
jtayl71
Post by jtayl71 » Thu Jun 07, 2018 12:48 pm
Gabrio,
I tried just this and none of the scans were registered together. They had lost all of their coordinate data and seemed to just be the raw data taken from the scanner.
gabrio
Forum Supporter
Forum Supporter
Post by gabrio » Sat Jun 09, 2018 1:05 am
hum, what a strange. we register scan from a zf imager 5010 with laser control. we save the register matrix in the zfs file, then export zfs file and import in recap skipping registration. that’s all. well, i never used LFM. sorry for the wrong tip.
+39.035.601.1492
mcraig4
Full Name: Matthew Craig
Company Details: Visual Precision Solutions LLC
Skype Name: matthew.craig4
Post by mcraig4 » Sun Jul 08, 2018 12:51 pm
Sorry for the late reply, but I have not been on the laser scan forum in a while. There are three workflows for converting an LFM dataset to ReCap; unfortunately, they both involve having to get a license from AVEVA LFM or subcontract a service organization to do it for you.
1) Within the LFM Gateway Register (version 4.4.2.12 or later) you now have the ability to write the transformations headers back into the .zfs files, which can then be opened and processed through ReCap following the procedure referenced earlier.
2) Within LFM Server you can save a specific volume of points comprised from all the scans, which can be focused on a specific area of interest and at a defined resolution. This volume then can be exported out into a .rcs formated file, which can then be opened in ReCap.
3) Within LFM Gateway you can export each ZFC file to the neutral file format .e57 then the e57 files can be brought into ReCap.
If the dataset was registered was registered within LFM then all three workflows will provide the laser scan data in the correct registered coordinate frame.
I hope this helps.
Matthew S. Craig
Visual Precision Solutions & Becht Engineering
danielproulx
Full Name: daniel proulx
Company Details: Wood
Post by danielproulx » Mon Oct 15, 2018 6:51 pm
Just learning here please point me in the right direction if I am repeating known info. Thanks...
So I have an LFM folder structure with the LFM file (along with lfs,lfd) on the top level.
I have folders for .geenrationdata, config, pngs, points and clashes
The points folder contains files with the POINTS extension. Will your procedure work the same?
Do I have to know how the points were made?
Great Thanks and regards
Graham
Full Name: GrahamM
Company Details: AVEVA
Post by Graham » Tue Oct 16, 2018 9:39 am
What you have there is a LFM generated dataset, all the source scans have been spatial indexed into the point files. If you no longer have access to the ZFC/ZFS files then you will need to go with option 2) previously mentioned.
danielproulx
Post by danielproulx » Tue Oct 16, 2018 1:08 pm
Graham
Thank you for your reply.
Return to “AVEVA Suite”
