Surphaser applications and technical information
Discuss all Surphaser related issues here.
dirdim
Full Name: Michael Raphael
Company Details: Direct Dimensions Inc
Post by dirdim »
Click the link below for applications and technical information about the unique capabilities and features of the Surphaser:
Surphaser Laser Scanner
Contact us directly for further technical, application, and sales information.
Michael Raphael
Direct Dimensions, Inc.
rapid solutions to 3D problems...
Baltimore, MD USA
410-998-0880
masimo
Full Name: Maxim
Company Details: PromGeo - Industrial Geodesy
Company Position Title: 3d scanning engineer
Country: Russia
Skype Name: massimo_XX
Re: Surphaser applications and technical information
Post by masimo »
Looks like it takes very clean scans. Could you upload some RAW data at different distances?
cerene_olivier
Full Name: olivier boissard
Company Details: GGC
Company Position Title: laserscanning surveyor
Post by cerene_olivier »
Hello
What is the best resolution for these scanners ?
Olivier
dirdim
Post by dirdim »
Hi Olivier,
The scan density control is software selectable within the following ranges as per the current specifications sheet:
Min. Vertical Point Density (points/degree) 24
Min. Horizontal Point Density (points/degree) 10
Max Vertical Point Density (points/degree) 90
Max Horizontal Point Density (points/degree) 90
Happy to answer any questions about the Surphaser, it is an amazing scanner!
Michael Raphael
Baltimore, MD USA
410-998-0880
Mrrl
Full Name: Andrey Astrelin
Company Details: Basis Software
Company Position Title: Algorithms Developer
Country: Russia
Skype Name: andrey.astrelin
Post by Mrrl »
Olivier,
For standard configurations maximal point density is:
vertical - 92 Points/degree
horizontal - 180 Points/degree.
For special configurations vertical resolution may be up to 460 points/degree.
What resolution are you looking for?
cerene_olivier
Hi
Thank you for your replies.
I own Leica HDS 6000 and I try to find out which scanner could be more accurate.
But are you talking about Surphaser® 25HSX ?
I search laser scanner that could have a precision < 1 mm with middle range .
In fact I must inform me because some client request very high level of precision.
For the moment I am not able to get such job.
How is it with registration?
Does it use target too ?
do we lose a lot of precision while registrering scans from difference scanpositions ?
Olivier
Mrrl
Country: Russia
Post by Mrrl »
Hi
Surphaser gives accuracy <1 mm in range from 1.5 to 10-15 meters. There is some marker extraction feature (for checkerboard and round markers), but it doesn't have scan registration feature. So registration should be done in another software (Cyclone, Polyworks,...). Export of ptx files is possible and it's the way how most users process Surphaser scans.
Ryan
Full Name: Ryan Frenz
Company Details: Autodesk
Post by Ryan »
Mrrl wrote: So registration should be done in another software (Cyclone, Polyworks,...). Export of ptx files is possible and it's the way how most users process Surphaser scans.
But PTX discards all error information about the device (range +/-, angular uncertainty, etc). How can proper registration/processing be done without this?
Ryan
Mrrl
Country: Russia
Post by Mrrl »
Ryan,
Do you know any popular format that contains such information and software that can use it for registration and processing?
Andrey
Ryan
Post by Ryan »
Andrey,
Mrrl wrote:Ryan,
Andrey
I do not know of a format. LAS, maybe? I don't really use 3rd-party registration/processing packages, but I would guess that they have some way for you to specify expected errors in the data. The survey processing packages all have this ability.
Return to “Surphaser”
