Riegl launches VZ-1000 scanner, with 1.2km range
Latest Press Releases from the Manufacturer
joe.3dlm
Full Name: Joe Beeching
Company Details: GeoSLAM Ltd
Post by joe.3dlm »
NEW RIEGL VZ-1000 Terrestrial Laser Scanner
Following the success of the ground-breaking VZ-400, Riegl have raised the bar again with he launch of it's big brother, the VZ-1000.
Key specs:
- online waveform processing, for calibrated reflectivity readings and multiple target extraction
- maximum range 1,200m
- repeatability 5mm
- measurement rate up to 122,000 Hz
- field of view 100 x 360 deg
- LAN/WLAN interfaces
- operated by any PC/notebook or cableless
- optional D-SLR camera (Nikon D300(s), D700)
- 31GB internal storage, expandable using USB2 interface
Registration Methods:
- stand-alone registration, using integrated GPS receiver (L1), biaxial inclination sensors, integrated digital compass
- via control points, using automatic detection and fine-scanning of retro-reflective targets
- totalstation- like, using setup over a known point with laser plummet, inclination sensors and backsight to target
More details here:
http://www.riegl.com/nc/products/terres ... canner/27/
Datasheet:
http://www.riegl.com/uploads/tx_pxprieg ... MINARY.pdf
Orders being taken now! Pricing information from your local Riegl distributor: http://www.riegl.com/nc/company/iriegli-worldwide/
Those attending INTERGEO 2010 can see the official launch for themselves and see the new scanner in action - we expect a big crowd!
Joe
Has thanked: 40 times
Been thanked: 18 times
Re: Riegl launches VZ-1000 scanner, with 1.2km range
Post by Jason Warren »
Hello Joe,
When do you expect to have one in the UK?
joe.3dlm
Post by joe.3dlm »
Jason,
We should have one in late August / September. It's pretty much replacing the LMS-Z420i in the Riegl range, so we expect the majority of buyers to be in the mining industry (therefore not in the UK!)
Joe
Return to “Press Releases”
