E57 Export
- ddustin
- Full Name: David Dustin
- Been thanked: 11 times
E57 Export
The manual for V8i says
"New Supported Point Cloud Formats
Bentley Pointools V8i now supports the ASTM committee E57 format for import and export, which aims to provide a universally available interchange format."
Yet when I select export, there are only .dxf, .pod, .pts and .xyz available..
Am I missing something?
David
David
- sealund
- Forum Supporter
- Full Name: Erik Hagestrand
- Company Details: Bjerking AB
- Company Position Title: Surveyor - Laserscan technician
- Country: Sweden
- ddustin
Re: E57 Export
That is obviously the way it is, but the wording of the manual would indicate otherwise.
David
David
- Mike Annear
- Full Name: Mike Annear
- Has thanked: 122 times
- Been thanked: 196 times
Re: E57 Export
Hi David,
I just checked all the export options in SS3 and Descartes..you are right, it doesn't seem to export E57.
Export it out of Bentley as an XTZ file, import it into CloudCompare, then export it as an E57 file.
Its a bit long winded but Cloud Compare is a very fast converter,
Mike.
Mike.
- DanCutler
- Full Name: Dan Cutler
- Company Details: Bentley Systems
- Skype Name: dan_pointools
Re: E57 Export
The statement is a little ambiguous. Bentley Pointools supports import of E57, but not export.
- masimo
- Full Name: Maxim
- Company Details: PromGeo - Industrial Geodesy
- Company Position Title: 3d scanning engineer
- Country: Russia
- Skype Name: massimo_XX
Re: E57 Export
Btw, what is special in the E57? Does it support point normals, scanner positions and intensity/RGB colours?
- Full Name: Jed Frechette
- Company Details: Lidar Guys
- Has thanked: 62 times
- Been thanked: 219 times
Re: E57 Export
The quoted statement from the manual doesn't seem very ambiguous to me. False yes, ambiguous no.DanCutler wrote:The statement is a little ambiguous.
This paper http://www.ri.cmu.edu/publication_view.html?pub_id=6767 describes the format and its goals. Basically, providing an extensible vendor neutral format for data interchange. As to your second question, yes it can store all of those.masimo wrote:Btw, what is special in the E57? Does it support point normals, scanner positions and intensity/RGB colours?
- DanCutler
Re: E57 Export
OK, let me re-phrase the sentence:False yes, ambiguous no.
Pointools now supports the ASTM committee E57 format, which is a point cloud format for import and export.
That is how I intended it to be read. At the time of writing I was not certain if it would be included as an export format, so it was not mentioned specifically. Apologies for the confusion.
Re: E57 Export
Fair enough, I didn't mean to sound to critical. I completely understand if features needed to be trimmed to get the software out the door. Is export support planned at some point?DanCutler wrote:That is how I intended it to be read. At the time of writing I was not certain if it would be included as an export format, so it was not mentioned specifically. Apologies for the confusion.
- I have made 30-40 posts
- Full Name: Chris El-Araj
- Company Details: Underhill Geomatics Ltd
- Has thanked: 3 times
Re: E57 Export
I recently installed Pointools 64 bit version 2.00.02.10, and they seem to have removed support for importing E57 format. It is available with version 2.00.01.01 but not the current one? Can Dan or anyone comment on this?
Thank you,
Chris
http://www.underhill.ca
Thank you,
Chris
