amberg users
Discuss all Amberg related issues here.
cerene_olivier
Full Name: olivier boissard
Company Details: GGC
Company Position Title: laserscanning surveyor
amberg users
Post by cerene_olivier » Thu May 24, 2012 8:34 am
Hello
is there any amberg TMS users on this forum ?
In noticed only a few post ...
olivier
Phil Marsh
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Re: amberg users
Post by Phil Marsh » Thu May 24, 2012 8:49 am
cerene_olivier wrote:is there any amberg TMS users on this forum ?
Hi Olivier,
I'm an Amberg TMS user, is there anything you need to ask?
Phil
LASER SCANNING FORUM
cerene_olivier
Re: amberg users
Post by cerene_olivier » Thu May 24, 2012 10:30 am
Hi Phil
I imported a HDS6000 pointcloud into TMS Tunnel.
I extrated profil with TMS profit
There is a lot of work to do to clean it.
I wonder if it was possible to clean several profil at a time ( because the same noise data appears in consecutive profiles) ?
Is it possible to reject isolated point after profil generation ?
Olivier
Phil Marsh
Re: amberg users
Post by Phil Marsh » Fri May 25, 2012 10:38 pm
Hi Oliver,
It is possible to delete (MASK) points in the scan data (Map view). After the masking these points are not visible in the profile data so do not show after the export.
I hope this helps?
Phil
[email protected].com
cerene_olivier
Re: amberg users
Post by cerene_olivier » Tue Jun 05, 2012 10:27 am
Hi Phil
I don't find where to mask these points.
In which module ? ProFit ? scanrex ? scancloud ?
Is it possible to mask for ALL profils ?
Olivier
cerene_olivier
Re: amberg users
Post by cerene_olivier » Tue Jun 05, 2012 11:28 am
Hi
I realized you probably tought about scanCloud.
As a matter of fact it is possible in this module to mask scan data but AFTER processing
The problem is that I have huge quantity of data in this scan and the process is very very long
So I try to generate profils without surface data processing.
That 's why I try to clean data before data processing.
Do you know a method to mask these points BEFORE data processing ?
Olivier
markko
Full Name: Marco Meroni
Company Position Title: Tunneling and Rail Technical Support
Re: amberg users
Post by markko » Mon Jul 02, 2012 10:33 am
in TMS you can't mask point before data processing. But to have a quick results from processing you can try to use the "Quick Processing" option in the "Processing Parameters".
With this option you can reduce the cloud projection to obtain quick results (for example directly in the tunnel).
I hope this can help you.
Markko
cerene_olivier
Re: amberg users
Post by cerene_olivier » Fri Aug 10, 2012 11:42 am
I don't see where you mean there is a quick processing option ...
markko
Re: amberg users
Post by markko » Thu Aug 23, 2012 9:35 am
This option is available in TMS version from:
1.9.0.0 [approximately October 2009]
You can find the "Quick Processing" option opening "Scans" in the Workspace of TMSOffice, then go the menù:
"scans" >>> "processing parameters"
In this window you can see it (in the bottom part of the window).
Ciao
Markko
Return to “Amberg”
