TMS Tunnelscan - Complete tunnel information at a glance
Discuss all Amberg related issues here.
Phil Marsh
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Post by Phil Marsh » Tue Jun 24, 2008 8:12 am
Thanks to the latest scanner technology, TMS Tunnelscan produces tunnel documentation to a new high level of quality, at previously unknown measuring speeds.
Optimal results
* Complete profile checks
* Non-destructive layer thickness measurement
* Surface quality checks (undulation)
* Scaled image documentation on tunnel features, work stages and actual condition of structure
* Detailed dimensioning for optimised logistics and billing
Comprehensive tunnel as-built analyses: Fast, precise, meaningful
TMS Tunnelscan is the powerful data collection and evaluation software for laser scanner measurements in tunnel projects. Together with the Profiler 5003 high-performance imaging scanner from Amberg Technologies, TMS Tunnelscan forms the most powerful system solution on the surveying market for tunnel as-built documentation and analysis. TMS Tunnelscan supplies reliable information for the tunnel contractor, client, designer, and not least the surveyor.
Powerful software routines
* Record the geometry and image of the entire tunnel structure during each construction phase
* Determine all areas of under and overbreak
* Calculate detailed excavation quantities
* Compare measurements taken at different times for determination of sprayed concrete layer thicknesses and spatial deformations
* Check the conformity of undulation of tunnel surface layer
* Process georeferenced scanning data from other scanner types through standard PTS data interface.
TMS Tunnelscan users benefit from
* Automatic data acquisition and evaluation software specially designed for tunnelling works
* Highest performance with up to 500,000 measured points per second (Profiler 5003 from Amberg Technologies)
* Unique measuring speed at highest data density – up to 10’000 times more powerful than conventional methods
* One set of data for geometric and digital image documentation of the tunnel
* Mobile, autonomous and modular system design for optimal integration into the construction process
TMS Tunnelscan supports the following workflow
* Input of project data (axis, transverse slope, theoretical profiles,…)
* Data capturing using TMS ScanControl in combination with a Profiler 5003
* Import the measurement data back in the office software (Profiler 5003 or through PTS interface)
* Process the scan data based on given design elements
* Extract single profiles
* Process a wide range of reports in different formats (under-/overbreak, undulation, volumes,…)
http://www.amberg.ch/at/index.php?id=79&L=0
Re: TMS Tunnelscan - Complete tunnel information at a glance
Post by Jason Warren » Tue Jun 24, 2008 7:27 pm
Hi Phil,
Is that a round prism attached to the scanner? Can you get the attachment for the Leica HDS6000 or is it just available for the Amberg 5003?
Jason
cwxTools
http://www.cwxtools.com
High Definition Surveys Ltd
http://www.highdefinitionsurveys.co.uk
Phil Marsh
Post by Phil Marsh » Tue Jun 24, 2008 10:10 pm
Brochure_TMS_Tunnelscan_en.pdf
Phil Marsh
Post by Phil Marsh » Sun Jul 06, 2008 9:55 pm
Phil Marsh
Post by Phil Marsh » Sun Jul 06, 2008 10:00 pm
Profiler5002_5003_1.0.0.1_en-2.pdf
Briareos
Full Name: Mike Coman
Company Details: Globe Shanghai Co. Ltd.
Company Position Title: project manager
Post by Briareos » Sun Aug 23, 2009 6:59 am
Does anybody know, how do Amberg manage to register the scans ?
As i know they use the Z+F laser scanners as Leica also does.
We also use a Leica HDS6000 therefore I would like to replicate it.
The only information I have is the photo, that you published above with the prism.
As i can understand it says something like.
By means of Total station the prism on the Laser scanner is measured onece before the scanning job and once after the scanning job. Then one aditional tilt and turn target is measured by means of total station, and also during the scanning job by the scanner.
As probably all the users are trying nowadays to minimize Total station workflow due to extra setups, this is golden information.
This is my presumption:
I tried to figure it out and I think the laser scanner must always start scanning from the position at which is curently oriented and then will always stop 180 deg opposit from the start position.
Based on this presumption, the middle point on to the line created by the 2 measurments to the prism, will define the X,Y of the nodal laser point and the Z will be a precise known diffrence.
The Tilt and Turn or Sphere target will define the orientation for the scanner.
All this measurments should be constrained by the TPS. For this probabil scenario to function, the Laser scanner should have the Tilt Sensor on.
Now my questions are:
Does anybody know how does it realy works?
Did anybody seen it in action?
Does anybody know if it's possible on the HDS 6000 to redify the scanning start stop parameters in such a way that will always start from the actual position without going back or forward to it's own setup start position? The same is valid for the end position, 180 deg from the start?
Does anybody know how to rewrite the ZFS file orientation matrix?
Does anybody know how to manyaly change pointcloud orientation matrix after import into cyclone?
Does anybody know how to make a registration without any targets or cloud to cloud constraint into cyclone?
Well I know there are a lot of questions, but there is a lot of processing power on this forum :D , we could solve it together, or at least we will know what to demand from the manufacturers.
If the above would be met, I belive a simple excell calculation will do the trick, and sudenly the on field workflow will become less constraint.
Thank you everybody for any input into the mater.
Phil Marsh
Post by Phil Marsh » Sun Aug 23, 2009 8:08 am
Hi Mike,
These are very good questions that I am sure some one will try to answer if they can without giving too much away.
Amberg have a good project report from Alp Transit Gotthard AG, on their website, which shows undulation analysis and the scanner in action. This file can be found below:
Reference_Ebenheit-GBT_en.pdf
or http://www.amberg.ch/at/fileadmin/docum ... GBT_en.pdf
I am not sure if anyone from Amberg is on the forum yet who could explain how this works. Maybe we can track down the guy in the image below to explainb how the system/software works?
More information can be found at http://www.amberg.ch/at/index.php?id=104&L=0
Post by Jason Warren » Sun Aug 30, 2009 8:54 am
how did you get on?
cwxTools
Phil Marsh
Post by Phil Marsh » Sun Aug 30, 2009 9:04 am
I sent an email to Amberg inviting them to the forum but I never got a reply. However I could only find a general email address and not sure if this would get past the receptionist. It would be better if I could find an actual person to email. I will keep trying.
TecnoMA
Full Name: Mauro
Company Details: TecnoRilievi
Post by TecnoMA » Mon Sep 06, 2010 11:18 am
Hi to all, here there are some sample images of informations that you can extract with Amberg TMS Office.
Sample images
The zfs file orientation matrix is written in the zfs file after the positiong operation (postprocessing) in TMS Office
If you want to import the zfs file with the correct cordinate system you have first to position the scans in TMS Office (file orientation matrix), import all the scans in Cyclone and then you can merge all the modelspaces into new one (In MS, file-->merge from Modelspace and select the imported files).
Another important thing is that TMS Scancontrol (the field software for controlling the scanner) allows the user to set the 50hz speed for the scan, so in less than 1 min (51 sec for 50hz and 5000 pt/sec) you can finish the entire scan.
Hope you find this information useful..
Mauro
Return to “Amberg”
