DIY COVID-19 Thermography Screening
To chat about anything else.
jcoco3
Full Name: Jonathan Coco
Has thanked: 27 times
Been thanked: 57 times
Post by jcoco3 »
This morning I setup a simple way for individuals to check their temperature in our office lobby. If you are have a thermal camera on hand you can set one up too. All you need is a thermal camera, a monitor, and a way to connect them. I also set the camera to show max temps within a narrow rectangle, and also to black-out any temps above 100°F. I printed and taped the user instructions on the wall next to the camera, so anyone can check themselves(see attached). I have also attached the documentation on which I based this approach.
Temperature Check.docx
ebola 1.pdf
Hopefully you will not need this, but for those fortunate enough that can still go to work, then maybe something like this will help keep it that way :)
Return to “General Chat”
