presentation and doubt about the appropriate scanner for tanks
Introduce yourself.
Daniel Marcos
Full Name: DANIEL MARCOS DIEGO
Company Details: Hito1
Company Position Title: CEO Hito1
Country: España
Post by Daniel Marcos »
Hello, my name is Daniel Marcos, Geomatics Engineer, I am from Asturias - Spain. I have a tank capacity cubing project, made of different materials (steel, wood, fiber) and approximate dimensions of about 3 m in diameter and 10 m in height. They have to be scanned from within. I have tried three scanners: Trimble X7, Leica RTC360 and Faro S70. The one that showed the best precision, after analyzing the point clouds and contrasting the data with the georeferenced inner targets, is the Leica scanner. Faro's has the same precision but more noise. And the X7 has the worst precision (up to 8mm uncertainty). Has anyone done similar work to guide me on the scanner to buy? Thanks and regards!
Carbix
Forum Supporter
Forum Supporter
Full Name: Daniel Loney
Has thanked: 20 times
Been thanked: 24 times
Re: presentation and doubt about the appropriate scanner for tanks
Post by Carbix »
whats your goal?
Daniel Loney - Owner
Excelsior Measuring inc.
www.ExcelsiorLevel.com
Daniel Marcos
Country: España
My goal is to certify the tank's cubic capacity with an uncertainty in the result of around 1%. You have to measure more than 1500 units, in different shapes and materials. I expected to find a scanner whose precision in the measurement of "short" distances was very high, since I see that the most precise has a precision of about 3 mm in many areas, I mean the term precision to repeat the measurement to the same point or one very close (1-2 mm). On the other hand, I expected not to obtain a lot of noise in the models obtained so as not to have to apply numerous filters in reducing it and to obtain the best estimate of the actual tank volume. I show images of cuts and measurements of 1mm sections in the point cloud obtained from the same tank with different scanners
Daniel Marcos
Country: España
rtc360 leica
Daniel Marcos
Country: España
trimble x7
Daniel Marcos
Country: España
faro s70
Daniel Marcos
Country: España
faro s70
Daniel Marcos
Country: España
When working for an industrial sector, accustomed to taking measurements below the millimeter, they do not conceive that my uncertainty in obtaining the diameter of a 3 m diameter tank is about 4-5 mm. By multiplying these 4-5 mm by the 10 m height of the tank, an uncertainty of many liters is obtained
landmeterbeuckx
Full Name: Lieven Beuckx
Has thanked: 55 times
Been thanked: 147 times
Post by landmeterbeuckx »
You should test this with a tof scanner, not a phase based.
LSBbvba
Tel : +32477753126
www.lsbbvba.be
Ioannis
Full Name: Ioannis Papas
Country: EU
Skype Name: -
Has thanked: 23 times
Been thanked: 17 times
Post by Ioannis »
Do you apply survey control to te targets with a total station?
Return to “Introductions”
