Alignment a cloud to other cloud in Build IT Construction
Please post all your polls you want others opinion on.
reverseengineer
Full Name: Duong Bui
Company Details: STAR GLOBAL EXPERT SOLUTIONS JSC
Company Position Title: Applications Engineer
Country: Viet Nam
Skype Name: Duong Bui
Post by reverseengineer » Thu May 17, 2018 3:26 am
Hi all,
My name is Duong. I am working for a 3D technology company in Vietnam.I encountered a problem when using Build IT Construction software. I want to align a cloud to cloud. I click on Measure>Alignment and Scaling>Cloud-to-Cloud Registration to align acloud to other cloud. However, this process is done automatically so it takes a lot of time. So I want to perform this process manually but I still have not found a tool to do this. I have found some tools such as Manual Alignment, Coordinate System… They only allow alignment a cloud to surface. I hope to receive feedback from everyone.
Best regards,
Duong Bui
JoshuaBigham
Full Name: joshua bigham
Company Details: FARO
Company Position Title: SR AE - BIM CIM Specialist
Re: Alignment a cloud to other cloud in Build IT Construction
Post by JoshuaBigham » Thu May 17, 2018 3:11 pm
Currently, you would need to fit corner points using Extract Corner in both scans that can be used in the Best Fit alignment tool. Then, use Cloud to Cloud registration with a higher sampling distance (default is for metrology levels, so use something larger to reduce time). Feel free to contact FARO support as well if you’re having trouble. support@farocom
JohnChan
Full Name: John Chan
Company Details: BuildIT
Company Position Title: Application Engineering Manager
Post by JohnChan » Thu May 17, 2018 7:06 pm
Yes, the method mentioned by Josh is perfect!
Extract Corner + Best-Fit (or even better: Bundle Registration - Select all extracted corners)
As you mentioned in your initial post, you can also use Manual Alignment command, with the Click and Drag method, you can also move the cloud per device/scan by simply clicking in the view (without SHIFT key).
Let us know via Support if you have any questions, we will be glad to help you!
Return to “Opinion Polls”
