Field Tested Target Spheres for Sale...
flemster911
Full Name: Glenn Fleming
Company Details: MEI
Company Position Title: Sr. Designer
Post by flemster911 »
I'm a newbie here, so here it goes... :shock:
I've been making target spheres (100mm, 150mm, 200mm) for local firms in the central Florida area for the past year.
I'm curious to see if anyone else would be interested in purchasing these low cost, reliable, shatterproof spheres.
Each size has been field tested with great results - green lights in Scene and green circles in Recap.
So far, I've made over 100 spheres of various sizes with no problems (the 200mm sphere is pictured below).
The spheres are made of:
- Shatterproof, UV resistant, matte white, durable plastic.
- PVC stand
- Chrome plated, strong-pull magnetic base
- Bolted construction for easy maintenance
If you're interested, please contact me.
Or visit http://flemster911.wix.com/spheres
Bulk orders welcomed...
Glenn
e: [email protected]
Some of my work...
Youtube: https://www.youtube.com/user/CGlennFleming
3DForensics
Full Name: Eugene Liscio
Skype Name: eliscio
Been thanked: 8 times
Re: Field Tested Spheres for Sale...
Post by 3DForensics »
Hi Glenn,
The photos is rather small, but is there a coating on these or are they made of some shatter-proof material?
Thanks for sharing.
Eugene
flemster911
3DForensics wrote:Hi Glenn,
Thanks for sharing.
Eugene
Hello Eugene,
The spheres are made of shatterproof, UV resistant, matte white, durable plastic.
I use them nearly every week and have dropped them from a height of 2 meters with no breakage, yet.
My supplier says they are NOT unbreakable, just shatterproof - but I have yet to break or even crack one.
Glenn
Oxbow
Full Name: Eric Bergholz
Company Position Title: CEO
Skype Name: eboxbow
Been thanked: 9 times
Post by Oxbow »
Hi Eugene,
it think shooter proof with durable plastic will be hard to achive. We have done many test last year with a much better material and it is hard to absurb the impact from the hit. And if you have a kind of holder or magnet on it, this make it much worst. In case of droping down, the sphere will fall every time on the same area in case of the weight. Same times a magnet or a holder works like a extension and push mush more crash power in the sphere.
Depend also form the ground, greenfield are easy, but concrete surface are hard.
regards.. ..Eric
flemster911
Just to be clear...
I made these spheres, more as a test project, to:
1. see if they would work,
2. find an alternative to risking $175 spheres out in the industrial environment.
After much field testing, and a few modifications later, this is what I came up with.
I have NEVER had ANY problem with them registering in Scene or Recap, or breaking out in the field.
And, of the 100 or so that I've made, none have been returned for any reason - dissatisfaction or breakage.
I'm a 3D engineering designer who scans frequently and I just wanted to find an affordable option for reference spheres that would work, both in the field and within my budget.
Visit http://flemster911.wix.com/spheres for product details...
Thank you,
Glenn Fleming
Me: http://flemster911.wix.com/online-cv
Samples of my work...
Point clouds:
https://www.youtube.com/watch?v=GshnsKDLw9I
https://www.youtube.com/watch?v=QCE29BDMMxs
3D Modeling from point clouds:
http://pano.autodesk.com/pano.html?mono ... 84949d9d8e
http://pano.autodesk.com/OGFhNzJjZmItZD ... hOTk5.html
http://pano.autodesk.com/YTVjNDNjM2YtMj ... iOGJh.html
flemster911
Re: Field Tested Target Spheres for Sale...
Just wanted to post an update to some of the scanning projects I've done:
http://www.moodyeng.com/#!3d-scanning/cw23
CWickersham
I have made 60-70 posts
Full Name: Caleb Wickersham
Company Details: EMJ Corporation
Company Position Title: Virtual Construction Engineer
Post by CWickersham »
Has anyone tried using spheres like: https://www.google.com/#q=foam+sphere+18+inch&tbm=shop
I'm interested in seeing if it would work or what would be needed to make it work.
Caleb Wickersham
emjcorp.com
flemster911
*UPDATE* Now we offer a 14-count styrofoam case for 200mm target spheres:
http://flemster911.wixsite.com/spheres/cases
flemster911
*UPDATED*
Here are some pics of our 8" (200mm) spheres and the 14ct EPS case for them...
If interested, please visit: http://flemster911.wixsite.com/spheres
Thank you,
Glenn
tbwester
Full Name: Thad Wester
Post by tbwester »
cool thx for sharing Glen.
Return to “Other Hardware”
