Kreon Laser Scanning Arm
- Full Name: Ali A
- Company Details: Self
- Company Position Title: Mechanical Designer
- Country: Pakistan
I am a beginner with 3d scanning and i recently scanned a simple flange using a kreon 7-axis arm with blue laser scanner. However, the resulting scanned geometry is very irrergular, as shown in the attachment. The online tutorials usually get perfectly accurate scanned data, while mine is clearly not. Is there some problem with the hardware or has it something to do with software settings?
- Full Name: James Senior
- Company Details: S-CAN 3D Ltd
Re: Kreon Laser Scanning Arm
It looks like the part (or base of the arm) has moved during scanning?
If you're sure it hasn't moved then I would calibrate the scanner. Make sure all joints in the arm are up to a stable temperature before calibration.
If you calibrate it successfully and it's still no better, it is possible there is something wrong and you'll need to get the arm/scanner sent off for repair/calibration. As a new user I'd hesitate before rushing down this route as you may be doing something wrong and it's difficult to say for sure without seeing what you're doing.
- Full Name: Ali A
- Country: Pakistan
Thankyou. I'll ty to make the base and part carefully clamped before scanning next time and check the results.
Althought when i calibrate the scanner i usually make sure that the standard deviation is within the specified range but i'll try to rule out the relative motion between scanner/part and get back to you.
