Tilt-Turn target questions
shannig
Full Name: Steve Hannig
Company Details: Hannig Surveying
Post by shannig »
Hello all,
I am a land surveyor with some prior experience with a Faro X330 and Scene. In the past I've only done cloud-cloud registrations.
I'm planning to add scanning to the surveying services I'm offering. For the time being, I have access to a Faro X330. I will be using Register 360 to create the cloud, and C3D with Cloudworx to extract linework when needed. Since I will likely need to combine scan data with conventional survey data, scans will need to be georeferenced onto a local coordinate system. So I'll need targets.
I'm considering the Leica 4.5 or 6" black and white tilt/turn targets, but have a few questions. Targets are expensive and I want to buy them once.
1. I understand that Register 360 will correctly detect the B/W tilt/turn targets?
2. Will an X330 correctly scan the targets so that R360 can use them?
3. In the future, it's possible that I'll purchase my own Leica C-10 or P-series scanner for outdoor survey-quality work. Are the B/W targets the correct ones for targeting with these scanners? For traversing, etc?
4. Leica also has (had?) blue targets with a white dot. Are these interchangeable with the B/W targets? Specifically, will they work with the X330 and R360 workflow?
Thanks in advance for your help!
-Steve
Has thanked: 45 times
Been thanked: 36 times
Re: Tilt-Turn target questions
Post by Matt Young »
As far as I know, the tilt and turn B/W targets are ok with the Faro. Just take care with the distances your acquiring them at. At lower resolutions you won't want them too far away.
Strider3D
Full Name: James Kennelly
Company Details: Zelus USA
Post by Strider3D »
You are better off with the black and white targets. The target poles with the Blue-Dot are specific to the C-10 and earlier models. I have successfully used black and white targets collected with the faro Focus 120 and M70 scanners in Register 360. Targets were autodetected on import. There is also a file that is installed with Leica Cyclone that you can print paper targets to use as intermediate targets. I think you would want at least 2 tilt and turn targets. The size difference determines the range at which they can be successfully detected.
P40 Black&amp;White target.pdf
HDS Black&amp;White target.pdf
shannig
Post by shannig »
Thanks for the info.
You're right, I could probably get away with two targets if my survey control is properly distributed throughout the project. 1-2 control points on each side of a building, for example. I do have access to a variety of spheres for registration purposes.
I'm leaning toward purchasing two 6" B/W targets. Do you know if the C10 will read the B/W targets, or will it only work with the blue dot targets?
Thanks!
Strider3D
Post by Strider3D »
The C-10 will work with the Black and White (actually the grey and white ones). If you are considering a C-10 purchase then get the tilt and turn grey and white for that unit. C-10 does not like the black color. The other scanners will read the grey and white, or you could take a look at the new Leica RTC360, this is an amazing unit that makes registration a breeze.
Daniel Wujanz
I have made 80-90 posts
Full Name: Daniel Wujanz
Company Details: technet GmbH
Has thanked: 32 times
Been thanked: 35 times
Post by Daniel Wujanz »
Dear Steve,
just a general remark: Most manufacturers recommend to use targets of this size up to a certain reach, usually 50 - 70 metres. That leads to a rather odd situation since the reach of most scanners is a lot larger. If you would scan for instance an object that is 300 metres away while registering it by targets that are a lot closer, you'll most likely get extra-polative (leverage) effects.
Thus, it is recommended to use overlapping regions between adjacent point clouds such as ICP-algorithm(s) or geometric feature-based approaches (e.g. planes or 3D-lines) in this case in order to fully exploit the inherent redundancy.
Daniel
Return to “Other Hardware”
