youtu.be/gBb7h63n1xs
Pretty neat little scanner...
Tech Specs
Electrical and Operating Requirements
Line Voltage: 100V - 240V AC
Frequency: 50Hz to 60Hz
Operating Temperature: 10° to 35° C
Size and Weight
Weight: 0.95 kg (does not include powerpack)
Volume: 50Hz to 60Hz
Finish
Al 6061 T6 Anodised and Bead blasted
Silver
Dark Grey
In the box
EORA 3D Scanner
Bluetooth Turntable (when purchased as a bundle)
Power adapter
Calibration Board
Wireless
Bluetooth 4.2 wireless technology
Range
Maximum recommended range of 1 meter
File Output
.PLY
.STL
.OBJ
Resolution and Accuracy
Full resolution capture of up to 8 million points
Sub-100 microns within scan range of 30 cm
Minimum feature size: 0.5mm
