Best scanner for reverse engineering machined parts
CWickersham
Full Name: Caleb Wickersham
Company Details: EMJ Corporation
Company Position Title: Virtual Construction Engineer
Post by CWickersham »
Greeting LSF,
What do you guys think the best scanner for the reverse engineering of machine parts is (bang for your buck? and if price isn't an issue?) with high accuracy
Some parts are reflective. Some parts have odd contours and hard to reach crevices.
Caleb Wickersham
Virtual Construction Engineer at EMJ Corporation
emjcorp.com
TommyMaddox
Full Name: Tommy R Maddox III
Company Details: ONSITE3D
Company Position Title: Director of US Technical Operations
Has thanked: 15 times
Been thanked: 11 times
Re: Best scanner for reverse engineering machined parts
Post by TommyMaddox »
We use and have had good luck with the GeoMagic Design X/Studio software in conjunction with the FARO EDGE arm with the Laser Line Probe.
One of the best aspects is the versatility and portability of the EDGE arm. We can use it for so many different tasks, from machine alignment to fixture/carrier checks to on-site inspection. We have even measured, modeled, and issued a quote-quality drawing on an extremely time critical part on-site within a few hours.
CKercheval
Full Name: Chris
Company Details: Z+F Usa
Company Position Title: Technical Support Engineer
Post by CKercheval »
We have a Case Study highlighting the use of Z+F Laser Scanners in the decommissioning of offshore platforms.
Dave Andrews
Full Name: Dave Andrews
Company Details: R.E. Warner Associates Inc.
Company Position Title: 3d Scanning Coordinator
Post by Dave Andrews »
Faro Arm with the Laser Probe, we are using Polyworks at the moment. We also use Vantage Trackers for this at times when it is possible.
I don't think there is a scanner on the market that will get you the accuracy you need. Most all of the Focus type scanners are +/- 2mm, I believe the Faro Arm is +/-0.002".
"The harder you work, the harder it is to surrender."
Woody Hayes
3DForensics
Full Name: Eugene Liscio
Skype Name: eliscio
Post by 3DForensics »
In terms of a scanner and what you get for your money, the new David Laser Scanner SLS-5 looks very appealing. It's less than $5k and has a dual camera setup using a projector with structured white light. In my opinion, it is one of the best value scanners out there on the market and the software now does 3D deviation analysis too.
If price was not an issue, I would say an "arm" type scanner as mentioned above. I have used the FARO Edge on many occasions and I hear it works best with Polyworks. I tend to use the native Cam2 software which is fine for my purposes.
Eugene
NOVAMECH
Full Name: Nick Bush
Company Details: NOVAMECH
Country: New Zealand
Skype Name: novamech5
Post by NOVAMECH »
Hi There
NOVAMECH uses:
ROMER Absolute Arm with Scanning Head - R1 - we are looking to service and upgrade to a R3 sometime soon.
ZF5010x
NDI OPTOTRAK PRO CMM - with ScanWorks Scanner
LEICA AT402 - Laser Tracker
DPi-8
HDS6100 - for sale at present
Software:
POLYWORKS
SOLIDWORKS
CYCLONE
LASER CONTROL
And with a month or so we will be moving into an AUTODESK product.
Take a look at our Web Site - for some examples of what we have been able to achieve over the last 8 years.
http://www.novamech.co.nz
https://www.facebook.com/NOVAMECH/ - like our page, we need your support, Thanks
Joe Parsons
I have made 90-100 posts
Full Name: Joe Parsons
Company Details: Magna Decoma
Company Position Title: Dimensional Lab Manager
Post by Joe Parsons »
I'd go ROMER arm, good quality scanning head (we've got a Nikon) and Polyworks. Done quite a bit of this stuff in the past, reverse engineering (i.e NURBS surfacing) isn't something you can pick up over night so make sure you include training with the software.
Joe
Return to “Other Hardware”
