Z&F 5010C - Screen Display
Discuss all Z+F related issues here.
anonimou
Full Name: Delio Pontes
Post by anonimou » Wed Apr 13, 2016 9:36 pm
Hi all
From the last month we are working with a new Z&F 5010C..
Working outside with normal daylight, after the scanner finish is very difficult to check the point cloud picture on the Z&F screen display.
So we are unable to make windows if we want to catch anything with more detail.
Only indoor we can see the pointcloud on the screen.
This is normal on this scanners? because before we had a HDS7000 and the screen display was much better.
images
image hosting free no registration
host image
photos upload
screen capture
hypsometric
Full Name: Arash Yaghoubi
Company Details: Hypsometric
Re: Z&F 5010C - Screen Display
Post by hypsometric » Sun Apr 17, 2016 1:58 am
On the main menu you should find a bright display button. This we designed to save battery on indoor scans but still allow for bright outdoor view however... its not really optimal. I find having a laptop and downloading the scans to via wifi is the best way.
anonimou
Post by anonimou » Thu May 05, 2016 8:14 pm
Arash, thanks for the reply.
We contacted Z&F and they sent us the solution.
You can plug in a usb keyboard on the scanner to access the bios.
Inside the bios you have a option to change the brightness screen display.
Our was setup to 50%, now we changed to 100%, and improved a lot.
sersab
I have made 60-70 posts
Full Name: Sergio Sabbatini
Company Details: 3DScan it
Company Position Title: CEO
Country: Italia
Skype Name: sersab
Post by sersab » Fri May 06, 2016 12:09 am
anonimou wrote:You can plug in a usb keyboard on the scanner to access the bios.
This is quite iteresting.
Can you please share the workflow to access the bios and the settings?
Thankyou
Sergio
3DScan - 3D Laser Scanning and topography
T +39 039 6980186 | Mail info@3dscan.it | Web http://www.3dscan.it/en/
anonimou
Post by anonimou » Fri May 06, 2016 12:49 pm
1. Plug in the usb keyboard on the scanner
2. Turn on the scanner and click the "delete" key several times to show the bios menu.
3. Go "advanced"
4. Go " Intel IGD SWSCI OpRegion"
5. Go "Backlight Control Fun" and change for what you need
6. Click "Escape"
7. Go " Save and Exit"
Done!
Return to “Z+F”
