SD Chip, What's the largest size memory for a FARO S350
Discuss FARO hardware here.
LPaulCook
8
Full Name: L Paul Cook
Has thanked: 39 times
Been thanked: 42 times
Post by LPaulCook »
What the most amount of memory on a SD chip will a FARO FOCUS S350 Scanners access?
I've use 32GB now, but using the FARO SWIFT mobile system I would like to increase the storage capacity for larger jobs.
Will a 64GB or 128GB work ok and will the S350 be able to use all that memory?
Thanks for your help.
L. Paul Cook, PLS
www.LPC3D.com
sim.herrod
Full Name: Simeon Herrod
Has thanked: 73 times
Been thanked: 107 times
Re: SD Chip, What's the largest size memory for a FARO S350
Post by sim.herrod »
LPaulCook wrote: Sun Dec 18, 2022 1:52 pm Will a 64GB or 128GB work ok and will the S350 be able to use all that memory?
We use 64GB cards in an S150.
martinuslv
4
Full Name: Martin
Company Details: GEO Development
Company Position Title: Laser scanner manager
Country: Latvia
Post by martinuslv »
S70 works fine with sd 128gb
LPaulCook
8
Post by LPaulCook »
But can the machine actually use/access all 128GB ?
L. Paul Cook, PLS
www.LPC3D.com
LPaulCook
8
Post by LPaulCook »
Answer found in the FARO Knowledge Base.
FocusM & FocusS
SDHC or SDXC cards are highly recommended.
Memory cards with a size up to 64 GB have been verified to operate with the scanner. The speed of the card must be Class 10 or better.
The SD card must be formatted in the FAT-32 file system. Although there are many ways to format memory cards, the most reliable way is to use the scanner's Format menu function (Manage > Service > SD Card > Format).
L. Paul Cook, PLS
www.LPC3D.com
LPaulCook
8
Post by LPaulCook »
Looking to replace my 32GB SD cards with the largest and fastest card that the FARO FOCUS S350 scanner can actually use all that storage and speed.
Yes, I see 1.5TB SD cards today, but can my S350 actually access and use that amount of memory?
I'm running my FARO SWIFT system which collects mobile scanning data as well as stationary scans so it stores tons more data than conventional terrestrial stationary scanning.
L. Paul Cook, PLS
www.LPC3D.com
Augusto 3D
9
Full Name: C-Augusto
Company Details: 3d scanning
Company Position Title: USA
Country: US
Has thanked: 115 times
Been thanked: 30 times
Post by Augusto 3D »
LPaulCook wrote: Thu Sep 21, 2023 3:28 pm Looking to replace my 32GB SD cards with the largest and fastest card that the FARO FOCUS S350 scanner can actually use all that storage and speed.
Hey Paul, I tried a 128MB card for the same reason as you, and nope, it did not work. So I just have 3-4 64GB cards.
I think what you also need is more Scanplan batteries.. that thing drains so fast.
LPaulCook
8
Post by LPaulCook »
I just bought a 2nd one of these huge batteries that have a built in inverter.
I put this in the basket on the trolly and run the charger with it connected to the ScanPlan.
This keeps that power hungry ScanPlan running for about 4 hours.
It takes a long time to recharge so I just bought a 2nd one today. $299 on Amazon. I'll have it tomorrow.
We live or die on batteries!
L. Paul Cook, PLS
www.LPC3D.com
Justin Richards
Forum Supporter
Forum Supporter
Full Name: JUSTIN RICHARDS
Has thanked: 32 times
Been thanked: 41 times
Post by Justin Richards »
We have been using the SanDisk Extreme PRO 64GB Class 10 SDHC based on FARO's recommendation. Most of ours are the 170MB/s and 200MB/s but they go up to 300MB/s now.
Leandre Robitaille
4
Full Name: Leandre Robitaille
Company Details: Cima+
Has thanked: 61 times
Been thanked: 230 times
Post by Leandre Robitaille »
Final blunt answer, 64gb is the limit.
Then to add to this, you do not want 64gb+ sd cards. You do not want to have more than 40gb+ on that sd card even, it makes the scanner slow. Even if you had a 256gb sd card, there is a diminishing return at some point and having to many scans on one SD card slows down menu handling on the scanner. I would say use 64gb sd cards with high read/writte speed but make sure that everyday the scanners have a fresh format.
With a 64gb sd card you can store up to roughly 300 scans+. Currently no way this can be achieved in a full day of scanning.
Backup your scans every night on your laptop + an external storage. Having 2 backups is just safe, do you really want to re scan a whole day for a dead ssd in your laptop?
10-4
Return to “FARO”
