nyterydur wrote: ↑Wed Jul 06, 2022 2:07 pmmaxwell566, the way we incorporate survey control into Scene that was ran as c2c is:maxwell566 wrote: ↑Thu Jun 30, 2022 6:23 pm Scene,trw only allows me to georeference scans to survey control. there isnt a workflow to apply a transformation to the scans to re register them to the survey control ( as far as i can tell ) this would be ideal. Register the entire project cloud to cloud and then holding the survey control to adjust the entire scan as a whole to the survey control. i dont see that this exists anywhere.>
1. We have a scans cluster containing all the scans properly placed and locked using c2c method
2. We create a Control cluster at the highest level and drag the scans cluster into it
3. We create a References folder within the Control cluster and import surveyed points or manually enter in points / checkerboard coordinates
4. Mark those same targets (points or checkerboards) in the individual scans they can be seen in
5. Rename the marked point to match exactly what that corresponding point is called as entered in the references folder
6. Run target based registration on the Control cluster, and select Force correspondence by manual target name
What step 6 does is it forces the program to only look for matching correspondence names and forces those correspondences, its just a clean way of doing it knowing that your reference point is not trying to refer to the wrong marked point for any reason.
but this isnt "stretching" the C2C cluster to fit the distances in the control network is it? - its just placing the cluster where it belongs.
