SCENE Center of Round Columns Problem
surveypm
Full Name: Tom Elbich
Company Details: Solid Ventures Inc
Post by surveypm » Fri Jan 11, 2019 4:12 pm
I have an interesting issue to solve which folks might have some ideas for the best way. I have a scan project of a warehouse with round columns. I’d like to extract the center point coordinates of each column (close to the base) using only SCENE and/or a free SCENE app.
I haven’t found a way to identify the center of a circle in SCENE and I want to find such coordinates so I can adjust the rotation prior to exporting the project to Recap.
Any ideas are appreciated.
MarkL
Full Name: Mark Lupton
Company Details: SEA
Company Position Title: LASER Scanning
Skype Name: markl9999@yahoo.com
Re: SCENE Center of Round Columns Problem
Post by MarkL » Fri Jan 11, 2019 4:14 pm
I haven’t ever used it, but I think scene can make cylinders from the points. That’d give you the xy of the central axis.
surveypm
Post by surveypm » Fri Jan 11, 2019 5:07 pm
Yes, thanks. I forgot about Pipe Fit tool. It's a little tedious and I see you should have a good Quick View of the column to be able to pick the points, but it does give you the axis.
LPaulCook
Full Name: L Paul Cook
Post by LPaulCook » Fri Jan 11, 2019 7:59 pm
You can use a clipping box to look inside the outside edge then dimension the diameter then set a point on the center of the dimension line which is where the distance bubble is connected to the diameter distance line as that is the radius point.
L. Paul Cook, PLS
www.LPC3D.com
Tgl_Nan
Full Name: Yan Koch
Company Details: TagLabs
Post by Tgl_Nan » Fri Jan 11, 2019 8:10 pm
We developed a plugin called "Extended toolbox". You can create circles and extract the center automatically.
You can force the circle to be horizontal.
We offer a free 3 days trial. This toolbox includes over 10 features.
Kind regards,
Yan Koch
yankoch@taglabs.fr
Return to “FARO”
