Manual Registration problem in Scene
- Full Name: Joel kirk
- Company Details: Fog city asbuilts
Newbie needs help! Every time I try and do a manual registration and I select two corresponding views - those views disappear after a few seconds and I am left looking at the colored background and the scanner head locations but no planar photo image for me to click planes and targets. What setting am I missing. Driving me crazy as I have a very small amount of tweaks before I can move on.
- sreed
- Full Name: Scott Reed
- Skype Name: sabotva
- Has thanked: 16 times
- Been thanked: 15 times
Re: Manual Registration problem in Scene
Suggestions from my experience, but not necessarily a fix:
Avoid the split correspondence view (SCV) - instead mark targets in planar view. This is a legacy behavior of mine and maybe Scene has gotten more stable in SCV.
- I have made 50-60 posts
- Full Name: Jason Sturniolo
- Company Details: Architectural Firm
- Has thanked: 5 times
- Been thanked: 3 times
So you click on registration and are able to select the two scans you want to register together. After that is when the screens go blank?
When I click on the two scans for manual registration I get the second image below.
Once I select the Mark Targets button I get the first image below.
I then can mark the targets.
Are you seeing any of this on your end?
- Nickel1
- Full Name: Nick Worrell
- Company Details: Atlantic Laser Scanning Services Inc
Honestly I prefer working in the old interface. The Split screen is much easier to work in. You may want to try it.
Nick Worrell
President
Atlantic Laser Scanning Services Inc.
Rental Provider of FARO 3D Laser Scanners
FARO Training
New Smyrna Beach, FL
(800) 955-3960
atlanticlaserscanning.com
President
FARO Training
(800) 955-3960
- Full Name: simon judd
- Country: United Kingdom
Hi All
You can of course bypass the Registration Tab and head straight to the explore tab.
Cluster your scans accordingly
open each scan in a quick view or planar view.
Manually identify the registration references (spheres, Checkerboards etc)
Once you have found all of the corresponding references for the cluster of scans Shift and Right click on the cluster and you will see that Operations/Registration/Place scans can now be found.
Just an alternative to the manual split screen type of approach
I hope that helps
Simon
I hope that helps
Simon
