scanning for open pit area and maximum distance with faro focus x330 scanner
Discuss all Faro related issues here.
Januar
Full Name: Januar kuspriantono
Company Details: PT Datascrip
Company Position Title: Support Manager Engineer
Country: indonesia
Skype Name: januar42halim
Post by Januar » Fri Oct 13, 2017 2:40 am
Dear Sir and Madam,
I have X330 Faro Focus and JRC software, we have problem went I scan in Open Pit mining area because the distance [ I already try max distance only 30m went I process Use cloud to cloud.
Because the furthest distance that can be processed with cloud to cloud is only about 30m with software scene in Open pit mining area,
if anyone can advise me how to do the scanning with FARO Focus so get distance of approximately 100 m and can be processed with cloud to cloud,
I am very grateful for the information.
Regards
Januar.k
you can direct email to me : januar@datascrip.co.id
Sharas
Full Name: Sharas Bandinskas
Company Details: Freelance
Company Position Title: Freelancer
Re: scanning for open pit area and maximum distance with faro focus x330 scanner
Post by Sharas » Mon Oct 16, 2017 1:06 am
Hi Januar,
make sure you are not using distance filter on the scanner
Januar
Country: indonesia
Post by Januar » Mon Oct 16, 2017 3:17 am
Dear Sir,
Is this distance filter [ view operations>filter>Distance Based ] ? how to set up the FARO X330 that can be scan until 100m [ for each position scanner ] and registered use Cloud to cloud ?
Regard
Januar.k
Jaymon
Full Name: Jaymon Read
Company Details: Architectural Graphics
Company Position Title: Architectural Graphics
Post by Jaymon » Wed Oct 18, 2017 9:54 pm
Make sure the Quality setting on the scanner is high enough. At quality 1-4x your setting how long the scanner will wait for a return on the laser. 4x should get you the full 330m capability, anything above 4x is super-sampling.
pomped
Full Name: Daniel Pompe
Company Details: FARO
Company Position Title: Software Developer
Post by pomped » Thu Oct 19, 2017 10:19 am
As Jaymon wrote increasing the quality setting up to 4x may give you more points in the distance because they will be measured more accurate and not deleted by filters.
Can you clarify your problem: Do you not get (enough) points far away from the scanner or is the registration not working?
Why do you think cloud to cloud registration in SCENE can only be used withing 30 meters? As far as I know the algorithm is not restricted to any distance but only needs the scans to have enough overlap to be properly registered. Maybe you can share some screenshots of your scans so that we get a better understanding.
Ccctucker
Full Name: Curtis Tucker
Company Details: Advanced Virtual Imaging
Post by Ccctucker » Fri Oct 20, 2017 12:17 am
Approximately how big is the pit?
Januar
Country: indonesia
Post by Januar » Tue Oct 24, 2017 3:37 am
Dear Friend
Mining area is 5Ha, they need to scan this area in 1 hours, because over there so many activity.
how about if User use Faro Focus S350 is there any different ? [ because this type has longer scan distance ]
Regards
Return to “Faro”
